Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
I make sure to go into my task manager and close everything that I know is not needed for the time. That way Poser call pull all the memory it can. Also I close my browser, they fight for memory and for some reason the browser always wins. Thats my advice, It helps me. Also like I believe Phil said, save save and save. :o)
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
Quote - What memory?Ram memory??I have 4 gb
You didn't say what kind of OS you have, but if it is 32-bit you can only address 3 Gb regardless of how much physical memory you have on board.
Basic things take about 0.5 Gb in windows so only 2.5 gb is available to Poser in 32 bit.
If you have 64 bit, there is not such a limitation
A little trick I learned from Bagginsbill, in case this might be ur problem:
http://www.renderosity.com/mod/forumpro/friendly_message.php?save&message_id=3666416
Helped me a lot ;o).
hi all,
in case of memory issues on 32-bit Windows, I did an extensive tutorial on it recently. It's in the Tutorials section.
Why reducing priority (I use Taskmanager for it, great for long renders) or separating processing should help, I don't know but it doesn't hurt either.
My Poser (8.3 in Vista 32) has the same symptoms, and crashes when switching to another Room. Switching from cloth room to material room is a favorite crasher, switching from cloth room to hair room and then to material room avoids crashes, and so on. Has nothing to do with memory or CPU, has nothing to do with scene complexity, getting the latest video-driver sometimes helps for a while.
Poser is just not 100% stable, so indeed, save frequently and before rendering or switching rooms in any case. Things will improve, given time. And get worse, in between. Software like Poser is more complex than the Space Shuttle, you know. Windows is more complex than Houston Space Control, and Microsoft has more programmers and performs more testing than NASA. So just let's enjoy the miracle of Poser ad OS's working together.
Have fun.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
okay,
in another thread I found a link into Smith Micro, on solving Poser weird behavior. One never knows.
Poser crashes when in a scene i have a lot of figures imported (human figures).It can render the scene normally but after that when i want to return to preview mode it crashes.Can i do sth to fix that??
Thanks
