Okay I found the answer. Apparently after importing a Poser animated object if you have it selected then go into the animation wizard to the (don't select any options on the way) Global Settings window there is a loop button. If you press that then go forward through the rest of the windows without pressing any other options to the point of finish this will result in the imported Poser animation repeating as long as you have a time line. So although the animation only lasts 5 seconds if I stretch the timeline to 15 seconds the Poser object will loop through and play its animation 3 times.
Hello.
I have a poser model that I animated and set to play in a loop using Poser 7. So when I play the model it raises its arm up and down continuously in poser. When I import the model into Vue 6 Infinite I set the check box to import the entire animation. When I play the animation inside of vue the animation only plays once. So I'm wondering, when you click the "loop" box in Poser is that an attribute that is exported or is that just something for poser to play the animatin sequence over and over again but Vue does not loop the animation when the poser model is in vue?
