Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
were you using them in 2010 Pro ?
maybe try to delete all the lights and reapply. These are just regular lights from what i was reading..not AO or IBL or IDL...unless you have set up IDL rendering....which then needs are as stated above
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
In scenes with only 2-3 lights GC usually gives a washed out appearance when light intensity is too high with un-corrected shaders.
Personally, I would try to learn some of the modern lighting techniques to take advantage of Poser Pro 2010 (which I see that you have).
You can use the Tone Mapping (HSV Exponential) with this light set but you have to decreases the intensity globally, almost not worth efforts.
As mentioned above, this is older light set for when people trying to fake Global Illumination.
The IDL in PP2010 is far better and easier to use once learning how
As others pointed out, this is a Poser 5-style light set.
If the light colors are shades of gray, they are being anti-gamma corrected - resulting in darker intensities for all of them. This is not worth dealing with. Use modern lighting which takes seconds to set up yourself (via IBL, or IDL+environment sphere) - or turn off render GC.
Also, the Daz skin shader is not set up properly except for non-GC rendering.
It includes hackage factors for getting skin to look right in the absence of GC. So it only works right if you do Poser 7 style rendering.
It will not look right with IDL or GC.
I havent got a clue why this is happening...?????
Please some expert advice is much appreciated.
