Wed, Feb 19, 3:24 AM CST
Forum Moderators: RedPhantom
Subject: Want help for PoserPro 2010
Haarspalter ( ) posted Tue, 02 November 2010 at 1:51 PM · edited Sun, 16 February 2025 at 6:54 PM
If I in a Poser scene an object click (only one click with the left button) it automatically moves the objekt.
Windows 7 (64), Radeon HD 5600, 8 GByte RAM.
Thanks for helping.
Snarlygribbly ( ) posted Tue, 02 November 2010 at 2:08 PM
I prefer to right click, then select the object from the menu that appears.
This avoids the problem you are experiencing (happens to me too) and it lets you select objects which are behind others.
Free stuff @ https://poser.cobrablade.net/
ErickL88 ( ) posted Tue, 02 November 2010 at 2:15 PM
A single quick left-click on an object really should just select it, not move it around.
( btw ... wusstest du, dass es auch ein deutchsprachiges Forum hier gibt?
http://market.renderosity.com/mod/forumpro/showforum.php?forum_id=12479
... da könnte mal bissel mehr los sein g )
Haarspalter ( ) posted Tue, 02 November 2010 at 2:21 PM
I have this problem now only with a new PC, before with Windows XP I did not have this problem.
I need only in the scene click and the selected object already moves.
At the moment I also manage I with it the object in the menu to select to change the parameters then.
Haarspalter ( ) posted Tue, 02 November 2010 at 2:22 PM
Quote - A single quick left-click on an object really should just select it, not move it around.
Ja, aber um es vorsichtig auszudrücken, dort bekommst du sicherlich keine Hilfe.
lesbentley ( ) posted Tue, 02 November 2010 at 4:53 PM
A left click on an item should not move it, so long as the mouse does not move. I used to have a muuse with a ball, and found it almost impossible to left click without moving the item. I now use an optical mouse, amd find that I can left click to select an item withou moving it (this is in P6).
DarkEdge ( ) posted Tue, 02 November 2010 at 7:11 PM
Quote - A left click on an item should not move it, so long as the mouse does not move. I used to have a muuse with a ball, and found it almost impossible to left click without moving the item. I now use an optical mouse, amd find that I can left click to select an item withou moving it (this is in P6).
Now if you can only find a keyboard that spell checks for you. :lol:
jk
