On your monitor controls lower the resolution and refresh rate until it comes on then you can fiddle with it some more using the on screen controls, if it says out of range then it means the resolution is set to high. start at like 800x600 or 1026x768. All my monitors are PC/mac compatible. I have viewsonic monitors.
Do atleast one thing a day that scares the hell outta ya!!
Thanks Clay....the problem being the screen goes black and I can't get the menu to fiddle around with, no matter what button or series of buttons I push on the monitor [the monitor is 2nd hand as well from a pc setup]...another helpful soul suggested I borrow a G4 friendly monitor and set it [the mac] up that way as it needs to be set in the mac's controls right?...anyhow that's my current quest to borrow a monitor..and a mac geek if I can so I can grill her/him for info and I do have a list, heh heh heh...I seem to need visual hands on types of learning experiences from past experience on the old A2000 and my first P90, so I'm aiming at that, thanks again mate.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Hmmm..interesting that monitor, unless something is either wrong with it or the video card, should start up at a default setting. Lets try this..shut the computer off by holding down the power button on the front, once its off start it again and hold down the apple+option +P+R keys on the keyboard all at the same time, continue holding those down until you hear the start up chime 3 times then let them loose see if that doesn't set it back to a basic setting, I've never used anything but macs for 20 yrs so feel free to fire me any questions you have.
Like I said it does work then stops at black...will try your suggestion when I'm in playing around time...20 years a mac man eh....I'd have stayed with Amiga myself if they had kept pace but trying to grab business clients rather than focusing on music, which they were lightyears ahead of even Mac then, and graphics...I had 4096 colours when intel had 16, was what killed them for me and none of my programs at the time ran on a mac....so intel it was...well AMD 3D really..never trusted Pentium for some reason. My original 3D software was/is Imagine3D, now dead but it still works for me.. ...
Once
I see
a sound
and
Sometimes
I had a similar problem once. It turned out to be the monitor cable.
Originally, I hooked the new monitor up with the old cable that was still attached to the pc, and I couldn't get the correct resolution. I then tried the cable that came with the monitor and by maqic all of these new resolutions turned up!
No cable came with this monitor but I think I've isolated the problem...he ran a CRT monitor and it's expecting that. Been getting some advice re: that situation on the mac forum here that I think I'll take a stab at...not too good at this stuff...more of a program user than a computer afficionado if y get my drift...I understand M$ quite well after 10years but am a total noob on a mac which seems all different..missing stuff on the mouse to start with...LOL...it's like trying to use blender after 10 years using Imagine3D...different worlds really.. ...
Once
I see
a sound
and
Sometimes
On a windows machine, it this scenario. I would boot into Safe Mode, and change the resolution into the lowest possible res and refresh rate like 640x480 or 800x600 @ 60hz. I would boot into normal mode and voila off it goes.
I would imagine, on the Mac there has to be a way that you can boot into a safe mode of some sort and lower the settings.
It sounds to me like the G4 had a high end monitor originaly that could handle whatever resolution and refresh rate it was set to and now your stuck at that resolution and the current monitor cant handle that resolution or refresh rate.
No, it had a CRT monitor and they typically have a 65Hz RR where LCD/LED monitors can only handle 60Hz...just have to reset that and I'll be fine....just never done anything on a mac and it's an alien landscape...hope can find the prefs for the monitor.....that'll be the trick
Once
I see
a sound
and
Sometimes
Tried it a gain using the Software install disc fo 9.1 and holding down Control at the chime till the desktop appeared but the same thing happened...got this message in blue on a black screen
out of range
68.7kHz-80Hz
had to hard shut down again with no desktop.....pray for me.. ...
Once
I see
a sound
and
Sometimes
Mods and Coords reading this....sorry for the duplicate post from the Coord. Forum
Hiya everyone...well most of you know of my burglary some weeks ago...well a pal who's been trying to get me on a Mac for years gave me his older G4 AGP model [MODEL M5 183] with everything but a monitor about a week ago...then yesterday I was given a FLATRON L 1950H flat screen monitor...set the whole thing up then up turned on the monitor, then the computer and it booted fine but when it came time for the Video Card to kick in it all went black [no desktop left] and I got a message from the monitor that my refresh rate was unsupported...does this mean the monitor is useless fro my mac....I have a pc/inte l[P3 of some sort] coming in the mail this week from a pal in Idaho so it's not wasted if it's useless on the mac but I really wanted to use the mac for my music as all the work I tried at my pal's place when he was using this G4 seemed way smoother than the work I've done on my pc/intel with identical software[melody assistant music writing software].
Any hints to make it work, or suggestions for a proper monitor will be gratefully received....
thanks very much up front for your help.. ...
I see a sound
and try to write it down
