Quote - hello,
i am trying to set up a backgroung picture in P8, as a reference for composition,
can anyone explain how to move , rotate scale this picture?
thank you for your time,
semi
Check out drgeep.com if you want a tut on how to integrate the background into the piece. The Doc has lots of great Poser info there. If you just want to put a picture behind your work as a guide then I would just use the one sided square in the P8 primatives and apply your background to it as a texture. You can easily scale and rotate the square then delete it when you are done or make it hidden so you can test render as you go and not have it interfer with your real background.
Hope this helps.
pdg
hello,
semi
