Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Mikes : Set all of vicki's facial morphs to zero then apply the morph target set at 1...that should fix the problems you're running into... Lalverson : Load victoria 1 or 2, select the head and load a morph target (morph target can be found in geometries folder under Anton's MW morphs)...set all of vicki's head morphs to 0, and the new target to 1...Now in your pose directory find Anton's MW Mat and apply promo girl to your victoria figure...good luck!
The liitle girl render here is showing just the texture on the toddlers default face. The morph target included is for Vicki and has to be hand loaded. :) Ya know, the old way. Files in the zip are: morph tarhet .obj 2 texture maps (head&body) 1 MAT pose to apply textures to Vicki. If you have doubts where the things are, just look inside the zip before installing the folders. Enjoy
-Anton, creator of
since 3-13-07
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
