Tue, Nov 26, 10:53 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Poser Pro 2010 SR1 - can't find "directory"
blonderella ( ) posted Fri, 03 December 2010 at 1:38 PM · edited Fri, 22 November 2024 at 7:49 PM
I am trying to run Poser Pro 2010 SR1 and am completely unable to get it to run.  The first error it throws up as soon as I try to run it is "Poser Pro could not be found on this system. The installation may be incomplete or has been relocated."   I click OK to manually locate my copy of Poser which is in C:/Programs/SmithMicro, then I get this error "Poser Pro is not in the selected directory", even though the exe is there.  I am unable to find a thread anywhere dealing with this particular issue, and I have googled and followed numerous threads for hours.  Any help would be appreciated.
Say what you mean and mean what you say.
nruddock ( ) posted Fri, 03 December 2010 at 2:48 PM
Are you sure you're trying to install an SR for PPr2010 and not one for the older PPro ?
blonderella ( ) posted Fri, 03 December 2010 at 3:05 PM
nruddock:  from their page, it looks like it is the correct update for Poser Pro 2010, unless I am grossly misunderstanding, see screen.
blonderella ( ) posted Fri, 03 December 2010 at 5:04 PM
problem solved, I redownloaded and ran the SR and it seemed to run fine
