Attached Link: http://www.dimension-x-interactive.com
To be honest I have not seen any tutorials on texture maps if that is for a body skin. Personally I had to learn the hard way but on the way I was given tips to create my model Character. A start point is open a template of the body that you want to apply the skin to. Then create a new layer (template must remin visible) and copy the skin texture to that layer. Once copied over remove the unwanted skin from the unwanted areas. Once that is done delete your orginal template and save your new body texture as the background. By the way this is just the beginning you need to do plenty of more work before its finished, but this is a starting point for creating your own texture. I hope this inspires you. Best of luck!! J HariaThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi gang, I have downloaded a number of great skins or textures maps, and I have a desire to creat one myself. Is there a tutorial some where, that will show me how to make a tex map from a blank template. Not jsut add to one, but to do the entire map. Thanks for suggestions all.
