Fri, Nov 22, 2:31 PM CST
Subject: Stoopid P7 Library Question
jt411 ( ) posted Fri, 31 December 2010 at 6:16 PM · edited Fri, 22 November 2024 at 9:23 AM
Hi everybody,
I just switched one of my Windows 7 machines from dual monitors back to a single monitor and for some reason Poser 7's Library Palette is gone.
I made sure it's checked in the Window pull-down and I tried relaunching Poser back to its factory state, but no luck.
Any ideas? Do I have to uninstall the whole darn thing?
Rance01 ( ) posted Fri, 31 December 2010 at 6:42 PM
Edit menu, General Preference: Launch to factory state does not fix the problem?  Can you view your UI dots and have you saved any configuration wherein the library palette is visible?
Using Windows 7 there is a folder at: C:UsersUSER NAMEAppDataRoamingPoser 7
The folder is hidden but if you type into the Exlorer address bar you can open the thing and see it's contents.  The preferredState.pz3 file is there.  Might be if you cut and paste those files into another folder and try booting Poser the program will revert back the original state.  I'd move them rather than delete them in case something goes wrong.
Once you get things back again you might save that original configuration in one of your UI dots.
Best Wishes,
Rªnce
