Sat, Dec 28, 8:02 PM CST
Subject: Specular Map?
Ejaz ( ) posted Tue, 04 January 2011 at 7:32 PM ยท edited Sat, 28 December 2024 at 7:45 PM
Hi,
I was looking in Vue 7 and unable to find where I can define a specular map for my 3D model.Thanks for the help!
Ej.
thd777 ( ) posted Tue, 04 January 2011 at 9:18 PM
The easiest way is to go into the function editor and add a "Texture map" type node (which type depends on the circumstances). Load the specular map into the node and connect it to the "highlights" output. Depending on what you want to achieve, you can also connect the output to highlight intensity and/or size.
See image above for an example.
Ciao
TD
Ejaz ( ) posted Wed, 05 January 2011 at 12:24 AM
Thanks for showing this!
bigbraader ( ) posted Wed, 05 January 2011 at 6:32 AM
You can also use "Variable highlights" and use one of the procedural functions, or get the exact same result as "thd777" suggests with "Edit Function", forces you into the function editor :)
