Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 12:41 am)
You can remove SKP/OBP/VOB import from the program wishlist; these formats are totally undocumented and you would have to spend months if not years reverse engineering them. SKP could be imported using the Google toolkit but, as it is 32 bit only binary DLL, it would kill the 64 bit build wishlist item (which is much more important).
You might add to the wishlist the support for Poser compressed files (I presume that they are just gzipped files) and, maybe, support for drag-and-drop mesh files from the Explorer.
Bye and thanks!!!
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
Quote - You can remove SKP/OBP/VOB import from the program wishlist; these formats are totally undocumented and you would have to spend months if not years reverse engineering them.
To be undocumented means nothing, 3ds and Poser files also are undocumented.
Quote - SKP could be imported using the Google toolkit but, as it is 32 bit only binary DLL,
It will be more easier and take less time to me to reverse engineering the SKP file than try to integrate Googles DLL into my app. The SKP file is not so difficult, at least for the moment I can extract the textures from it.
Quote - You might add to the wishlist the support for Poser compressed files (I presume that they are just gzipped files)
I have other app that convert compressed Poser files and yes, it are gzipped and can be opened with WinRar.
Quote - and, maybe, support for drag-and-drop mesh files from the Explorer.
Quote - If it's not in there, a command line interface that I could use to call up the viewer from my application given the path to a .pp2 :-)
All PropViewers since the first can use the file name as command line parameter. If you associate in Explorer a file extension to be opened with PropViewer, clicking on the mesh name it will launch PropViewer and it also works inside zip/rar/7z files.
The bigger problem is the 64 bit version, not due the application by itself. The problem is the compiler. I am using Borland C as the compiler, but to produce a 64 bit version I should have to use Microsoft's Visual C, something that I don't want to do. There are other compilers, but I don't know their status or the IDE interface that have, if any. As for the Assembler, it doesn't make any difference, I can create any code that I want,
The other solution would be to do a mixed app, with a 32 bit user interface and a 64 bit processing part, but I don't know how to switch back and forth between 32 and 64 bits threads.
Stupidity also evolves!
Dear kawecki,
you can get the Visual C++ 2010 from the Microsoft site (no need to buy Visual Studio Professional). It is free apart from having to register it (requires a live.com login if I remember well). It creates 64 bit binaries and you can use it with either MFC or .NET runtime. Should you think about .NET runtime, I would advise you to try C#. It is what C++ and Java should have been but were not .
Thanks a lot for the other information.
Do you really partly decode SKPs? do the whole job, announce it on the internet and you will become a star!
Bye and again lots of thanks.
Great, thanks, this is one of my must-have Poser utilities. I probably use it several times every day. There again, I have no life. :)
Quote - > Quote - You might add to the wishlist the support for Poser compressed files (I presume that they are just gzipped files)
This is true, and I have a copy of PoserUngzip, but it isn't as convenient. I have PropViewer associated as the default application to open OBJ and PP2 files, and can also use it to view other Poser files via "open with...". Being able to do this with compressed files as well would be very useful.
"All PropViewers since the first can use the file name as command line parameter..."
Thanks, that works fine. The biggest issue that I have is that without looking at the file in text mode, one can't tell whether or not it has internal geometry. For my app, it doesn't matter so much because I'm dealing with archives. I can peek in the pp2, pull any .obj reference and then unrar/zip the .obj and feed that to PropViewer. For general use though, it would be really nice if PropViewer looked for an external reference and then loaded the .obj if possible.
Somewhat OT, any idea why your png2rsr utility would hang in memory after exit? It appears to close down but in Taskmanager or Process Explorer, it's still running.
Until now, I still do not handle external geometry in Poser files. It can be a little complicated to locate the geometry files, many different runtimes, inside zip/rar files, the internal referrence not always is correct pointing to a location that doesn't exist, refference to many external objs and until now I ignore all the channels and morphs.
After all, PropViewer is not Poser and I have no interest in emulating or duplicating Poser. The main goal of PropViewer is a quick browsing of model archives, format conversion and some mesh cleaning.
The next thing that I am planing is to add channel processing of Poser models (translate, rotate and scale), so a multi-prop prop will have all its parts inthe right position and ready to be exported. I just did that with 3ds files.
Quote - Somewhat OT, any idea why your png2rsr utility would hang in memory after exit? It appears to close down but in Taskmanager or Process Explorer, it's still running.
If I remember it was a problem with XP. Download it again and if this problem is still there, let me know and I shall upload the right version.
I've had to revert to version 3, unfortunately. 3.2 crashed on a large 3DS file; the process kept running and had to be terminated from Task Manager. (I had the same problem as lmckenzie with png2rsr, but the latest version has fixed that. I'm on XP.) PropViewer 3 handles this same 3DS fine - I didn't get around to trying 3.1.
Also, the view by group / material functions didn't seem to work for me; or maybe I misunderstood them.
Quote - I've had to revert to version 3, unfortunately. 3.2 crashed on a large 3DS file
Have you downloaded the 3ds from some place? so I can test to see which is the problem.
Quote - Also, the view by group / material functions didn't seem to work for me; or maybe I misunderstood them.
You must check the "by group" option and then select one group or material from the listbox.
Quote - Have you downloaded the 3ds from some place? so I can test to see which is the problem.
It was the laboratory model that used to be at 3D Cafe - I think it was originally distributed with 3D Studio, in the pre-Max days, but I don't have any terms of use for it so can't pass it on. If I find something readily available that has the same effect I'll send you a link.
Quote - You must check the "by group" option and then select one group or material from the listbox.
Ah, got it, thanks. Since the list box defaults to showing everything, the "by group" option would seem to be superfluous - in other words, it wouldn't matter if it was turned on all the time?
Quote - Since the list box defaults to showing everything, the "by group" option would seem to be superfluous - in other words, it wouldn't matter if it was turned on all the time?
If you select a group or material checking and unchecking the "by group" you switch back-forth between the selection and whole model view. Maybe a better word instead of "by group" would be selection or selected.
" It can be a little complicated to locate the geometry files, many different runtimes..."
Good point. I only have one so I tend to think in those terms. I will just create a small stub loader to redirect for the external refs.
Thanks for the word on png2rsr. I will try re-downloading.
Attached Link: http://www.sharecg.com/v/47408/browse/Poser/PropViewer-3.2
WHAT'S NEWVersion 3.2 - January 2011 - One year before the end.
WISHLIST
