Forum Moderators: RedPhantom
Attached Link: http://www.voidtools.com/
If you just need to search for filenames - not search within documents etc. I recommend *Everything* - lightning fast and a tiny footprint - not sure if it works on 7 but probably."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
Quote - If you just need to search for filenames - not search within documents etc. I recommend Everything - lightning fast and a tiny footprint - not sure if it works on 7 but probably.
I use Everything on Windows 7 Pro all the time, but just like Windows Search, Everything has to recreate it's database every time you start up if you have external drives. While it's still faster than Windows search, this noticably slows it down if you have multiple large externals as I do.
"Everything works fine on Win7"
Ah, thanks - good to know. Apparently offline indexes are scheduled for the next release. That might be a partial solution - e.g. index the drive and then turn off monitoring. You'd still have to update the index periodically but at least you might have control over when that happens.
I really hate the search engine that comes with Win 7. It does not seem to let me pick out the folders or the drive I want to search. For example, I was trying to search for a Poser product called elk.zip on my external drive. No such luck. How does this search engine work? Anyone help me? Thank you!
