Tue, Oct 22, 12:56 AM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: wx.TreeCtrl GetIndent
PhilC ( ) posted Wed, 12 January 2011 at 1:39 PM · edited Tue, 22 October 2024 at 12:31 AM
Can someone please explain what this is. I wanted something that would quickly tell me the root/parent/child level of a tree item but unless I'm using this totally incorrectly GetIndent will not do it.
Thanks.
semidieu ( ) posted Wed, 12 January 2011 at 2:11 PM
Good question... also interested to know :)
  I'm using the basic 'GetItemParent' and GetNextChild function to read in a treectrl.
PhilC ( ) posted Wed, 12 January 2011 at 2:24 PM
Yep :)
I can parse a Poser file to produce a tree. I'm needing to walk the tree to reproduce the file. Saw the GetIndent method and foolishly thought that I could keep track of bracket levels with it.
semidieu ( ) posted Wed, 12 January 2011 at 2:51 PM
Just took a look at the documentation:
GetIndent
Returns the current tree control indentation.
   So it won't give you the indentation of the item (if this is what you want). I would use a function that would count the number of parent items using tree.GetItemParent() until you receive an error.
PhilC ( ) posted Wed, 12 January 2011 at 3:02 PM
That would work, thanks.
semidieu ( ) posted Wed, 12 January 2011 at 3:12 PM
You're welcome :)
