Fri, Nov 22, 6:44 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Carrara doesnt import all of the poser scene
charlesatlas ( ) posted Sat, 15 January 2011 at 3:45 PM · edited Fri, 22 November 2024 at 2:46 PM
I have a poser scene and it contains a wrestling ring, the V4 black lotus, michael 4 and the freak.  When I import it into carrara 8 pro it only contains black lotus with NO clothes on and no ring and no ropes or floor etc...any ideas?  Thank you.
Sueposer ( ) posted Sun, 16 January 2011 at 10:25 AM
When you click file>import> and you select the poser file, a menu comes up. Do you click anything in that menu?
charlesatlas ( ) posted Sun, 16 January 2011 at 1:56 PM
It already has the following clicked
import morph targets
import animation
import deformers
import camera and lights
charlesatlas ( ) posted Sun, 16 January 2011 at 4:41 PM
Okay..now where I am is I can now import the ring..but Black Lotus is in a corner and all her clothes are in the center of the ring..also her hair is over her face...funny thing is that the scene imports perfectly in Maya.
jt411 ( ) posted Sun, 16 January 2011 at 7:08 PM
Since nobody's said this yet, I guess I'll be the first: You're much better off putting the entire scene together in Carrara alone; cutting Poser out of the process completely :)
Technically Carrara hasn't supported the import of Poser scenes since either Poser 5 or 6; I first noticed issues whenever Poser Pro first came out. Poser content however is fully supported; just point Carrara to your Runtimes and you're good to go.
Another issue may be that Carrara isn't finding all of your Runtime paths; a common issue if you're using an external drive.
Also, after your Poser scene imports, you may need to re-conform clothes, hair, etc. Sometimes advancing Carrara's timeline to frame 2 fixes the issue as well.
Either way, you should at least try putting a simple scene together entirely in Carrara and see how it feels :)
charlesatlas ( ) posted Mon, 17 January 2011 at 11:35 AM
Thank you.  This is just weird as it worked before.
