Fri, Nov 15, 6:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 4:06 am)
Subject: hi
clsiu1984 ( ) posted Sun, 16 January 2011 at 7:53 PM · edited Fri, 15 November 2024 at 4:33 AM
I am wondering i have a problem with poser 7...I cant see the male body personal...trying to remove his pants...can somebody help me? I went to material..i click his texture body ...naked body..but his cloth still on it underpant.
hborre ( ) posted Sun, 16 January 2011 at 8:48 PM
Which model are you referring?
SteveJax ( ) posted Sun, 16 January 2011 at 9:44 PM
Casual Simon who loads by Default in Poser 7 most likely and his pants do not come off! You will need to load the Nude Simon instead.
clsiu1984 ( ) posted Mon, 17 January 2011 at 12:44 AM
I just did...its michael 4 guy..im trying to remove him..but i cant do it anything...so which file im missing? is it alot of file missing?
Medzinatar ( ) posted Mon, 17 January 2011 at 1:20 AM
You know it would be nice if you have some descriptive subject for title.
I replied to your other post with subject "hi",
then I am looking at this post with same title and is totally different subject, you make very confusing to the least
SteveJax ( ) posted Mon, 17 January 2011 at 4:18 AM · edited Mon, 17 January 2011 at 4:20 AM
The underpants on the default Michael 4 are on the texture. You will need to go to the Pose portion of your library and look for Michael 4 folder. There you will find "MAT Poses" which will change his texture from the default to the the nude.
If you are trying to do a nude render you will also have to purchase Michael 4 Morphs ++ because that is where you will find his genitals! They do not come with the free base figure.
clsiu1984 ( ) posted Mon, 17 January 2011 at 11:37 AM
Yea i already have it...where can i find mat pose?? I dont see it..can you give me a file?
hborre ( ) posted Mon, 17 January 2011 at 12:14 PM
MAT Poses are found under the Poses Category of your library.  They specifically should reside in M4's folder.
SteveJax ( ) posted Mon, 17 January 2011 at 3:19 PM
Not knowing whether or not you have bought and installed any textures for M4 it's hard to say. His free standard resolution nude texture pose is called !All_Natural.pz2 and the one with the boxer briefs on it is called !Body_BoxerBriefs.pz2. There's also a !Head_Bald.pz2 and a !Head_Hair.pz2 in the same folder which should be called  MATerials STD-Res and be under your Michael 4 pose folder.
Plutom ( ) posted Mon, 17 January 2011 at 3:53 PM
> Quote - Yea i already have it...where can i find mat pose?? I dont see it..can you give me a file?
Instead of going for the MAT file, let's try a different approach:  Lets go for the Michael 4 face, torso, and limbs textures.  See example.
Plutom ( ) posted Mon, 17 January 2011 at 4:00 PM
then in material room do this:
Plutom ( ) posted Mon, 17 January 2011 at 4:05 PM
then connect up node like this, do the same for the limbs and face
Plutom ( ) posted Mon, 17 January 2011 at 5:03 PM
Stevejax, yours is the better solution, we were working stuff at the same time and you beat me to it.  I saw your post after mine was finalized.  Mats are a lot easier to do than building one from scratch like mine.  Jan
SteveJax ( ) posted Mon, 17 January 2011 at 6:22 PM
Quote - Stevejax, yours is the better solution, we were working stuff at the same time and you beat me to it.  I saw your post after mine was finalized.  Mats are a lot easier to do than building one from scratch like mine.  Jan
Actually both are good for the OP  to learn. Eventually they will want to know how to edit materials anyway.
