Sat, Jan 25, 3:51 PM CST
Forum Moderators: Staff
Subject: Help! 3ds max->poser getting open edges in obj
RadioBox ( ) posted Sun, 23 January 2011 at 8:41 PM · edited Tue, 06 August 2024 at 7:28 PM
Hi I am currently designing a rifle for poser and the market place. The modelling was done in max and then exported as an obj and imported into poser to texture and set-up. Since its my first model for poser I had to go back to max,tweak the original and export again into poser alot of times.
Just today I noticed that on one of the parts of the model there are 2 open edges and some dents.  On the original there is no open edge, I am sure of it. I re-imported the mesh into max to check if it was the exported file but the mesh was fine in max, but when I import into poser the open edge is always there. How do I fix this pls and how can I avoid such in future as I plan to go from prop designs to conforming clothing. I want to finish the model already :( Any help will be most welcome, and I will answer asap.
jentron ( ) posted Sun, 23 January 2011 at 9:23 PM
Are all your normals lined up or do you have some flipped backwards?  Also, are you leaving complex polygons for Poser to triangulate for you?
EnglishBob ( ) posted Mon, 24 January 2011 at 3:28 AM
Could you post a wire-frame view of the offending parts? I suspect long, thin triangles which Poser doesn't handle well.
You should also avoid polygons with more than four sides as jentron says.
