Forum Moderators: RedPhantom
I haven't used the dials - as dials - in a long time. IMO it's simpler to type the values in rather than faffing around with the dial.
@ triangle 2010. Not necessarily. V3 worked in Pro Pack and - as was mentioned in another thread - has a higher poly count than V4. I agree that high poly models will slow things down but that was also a problem in Pro Pack; it isn't exclusive to later versions of Poser.
Another thing that helps is closing arrows for morph groups you are not using.
Also I had this problem badly just the way you describe and it is virtually gone since I got a mac pro 12 core. Although scrolling through the heirachy editor is still quite slow.
Love esther
I aim to update it about once a month. Oh, and it's free!
wow, that sounds like a great tip!
Sounds like its time for a system upgrade. What graphics card are you using for dual monitors? And at what resolution.
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
A dual core at 1.8 ghz and 2gb of ram really isn't fine for anything 3d. Its the reason your experiencing the lag your dealing with.
As for the graphics card, for dual monitors I would go no less than a radeon 4850.
It can be found used for around $60.
Here's the specs for what you have now.
http://www.amd.com/us/products/desktop/graphics/other/Pages/x1950-specifications.aspx
Quote - A dual core at 1.8 ghz and 2gb of ram really isn't fine for anything 3d. Its the reason your experiencing the lag your dealing with...
I'm using a Core Duo 1.8b GHz notebook with 2GB and Radeon x1300 with Poser 8 and Poser Pro 2010 under XP Pro and the performance is quite adequate.
I don't have any dial lag. My viewport display is openGL. My 3D settings on the ATI control panel are to use Aplication Settings for Anti-aliasing and Anisotropic Filtering, Catalyst AI at Standard, MipMap Detail at Quality, Wait for Vert. Refresh at 'Off, unless App. speciifes', and Adaptive Antialiasing and Triple Buffering are Off.
Good Luck...
PS, Make sure you have all of the service releases installed... http://poser.smithmicro.com/updates.html
"Oh - the manual says that? I have never read the manual - this must be why."Trust me, I'm all for squeazing all you can out of what you've got. I ran Poser 7 on a single core 1.2ghz with 512mb of ram for quite a while, and I can tell you it was no less than painful at times.
Everyones idea of adequate or acceptable is different and Poser 8 nor Pro 2010 were intended to run the way they are meant to run on those systems.
Nothing worse than having your ideas and creativity being limited by your system.
gosh wouldn't a general script that speeds them all up by however much we want be useful then!
I'm not so sure. iN the days when the dials were slow they all seemed to be very very unuseably slow.
Got another question for Poser 8. Since I use the parameter dials for most of my figure tweeking, its no doubt annoying that using the dials is about as slow as it can get. When I go to spin the dials, it turns into one long delay before I get any results. Is there a way to speed this process up? I have no trouble in Poser Pro Pack with this and I'm hoping it may be a simple fix. I'm running Windows 7 Home Premium with an Intel Core 2 1.87GHz and 2 gigs of RAM with a dual monitor display. Thanks for any help.
