Mon, Dec 23, 1:53 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Dumb question of the day list unpacking
grichter ( ) posted Thu, 03 February 2011 at 12:57 AM · edited Sun, 22 December 2024 at 8:35 PM
Semi rookie
But
InColorValue = [0.607843, 0.686275, 0.811765]
and print InColorValue returns
0.607843
0.686275
0.811765
to unpack the list I have tried several methods I have found on the net which lead me to believe this should work.
r1, g1, b1 = InColorValue
But based on all the various ways I have found on the net about unpacking tupols or lists I keep getting the following TypeError: unpack non-sequence
So I am doing something very basic wrong. What is it?
I want to feed the values into a material node using a .SetColor(r1,g1,b1)
Thanks in advance for any tips or suggestions
Gary
markschum ( ) posted Thu, 03 February 2011 at 1:07 PM
use an index
print  len(incolorvalue)
r = incolorvalue[1]
g = incolorvalue[2]
b = incolorvalue[3]
I dont remember offhand if the index starts at 1 or 0 but should be easy to check
www.python.org and get the manuals
adp001 ( ) posted Thu, 03 February 2011 at 1:50 PM
Because Poser Python is somewhat outdated (even with P8), try this:
<pre style="font-family:'courier new', courier;">
ar=[1.234, 2.345, 3.456] >>> ar [1.234, 2.3450000000000002, 3.456]
a,b,c=tuple(ar) >>> a 1.234 >>> b 2.3450000000000002 >>> c 3.456
markschum ( ) posted Thu, 03 February 2011 at 4:02 PM
thats a nicer method , noted , thanks .
grichter ( ) posted Sun, 06 February 2011 at 11:51 AM
Found my problem using what I assumed would work.  Based on conditions I import various other scripts and had a typo, that for the life of me I couldn't see. So the original problem is mute. But you examples make things even easier when I want to pick one out of the list or tuple.
Thanks a million
Gary
