Mon, Nov 25, 11:56 AM CST
Subject: how to create poser morphs?
ice-boy ( ) posted Sun, 13 February 2011 at 7:47 AM · edited Mon, 25 November 2024 at 9:03 AM
hello. i forgot how to make poser morphs for poser figures.
i wanted to make a morph for M4 without ears. so in blender i smoothed out the ears. i uploaded the head morph. but now i dont know how to save this as a morph pose.
thanks
arcebus ( ) posted Sun, 13 February 2011 at 8:23 AM · edited Sun, 13 February 2011 at 8:24 AM
Select the head.
Pulldown: Object - Load Morph target
Search for your obj file
Select it
Click ok
Tally Ho!, there it is!
TypoEdit
www.skin2pix.com
bagginsbill ( ) posted Sun, 13 February 2011 at 8:37 AM · edited Sun, 13 February 2011 at 8:38 AM
ice-boy didn't ask how to load a morph. He's asked how to save it as a morph pose file.
I'd answer if I knew how but I don't.
arcebus ( ) posted Sun, 13 February 2011 at 8:47 AM · edited Sun, 13 February 2011 at 8:48 AM
I once wrote a tut about that (using Poser and a texteditor only) have to dig through the darker parts of my drives, though.
Later ...
www.skin2pix.com
ice-boy ( ) posted Sun, 13 February 2011 at 8:49 AM
google didnt find anything that i could use.
i remember using a tutorial for APolllo Maximus but i can not find it.
arcebus ( ) posted Sun, 13 February 2011 at 8:50 AM
Just searching - but thats 18 TB on four machines. Will need some patience, I fear. (especially because I can't remember how I named it....)
www.skin2pix.com
arcebus ( ) posted Sun, 13 February 2011 at 9:04 AM
Ok - that one is in german.
Making a new one, back in an hour.
www.skin2pix.com
arcebus ( ) posted Sun, 13 February 2011 at 10:55 AM · edited Sun, 13 February 2011 at 11:02 AM
Here you go
http://www.skin2pix.com/freebies/arc_ManualMorphINJfilemaking.zip
contains a (hot-needle) tutorial on how to do it, plus two "empty" sample files with just the file structure.
Should work for you, but if you want to do that more often than just occasionally, check PhilCs (www.philc.net) "Poser Tool Box" or  Dimension3D's "Poser Tools"  here at his store. Both do an excellent job, for both the learning curve is not really steep... but in all cases: knowing WHAT the tools do, will not do any harm ;-}
*typo edit because of obvious keyboard collapse.... *
www.skin2pix.com
vilters ( ) posted Sun, 13 February 2011 at 4:32 PM
Select the head. Pulldown: Object - Load Morph target..
Search for your obj file. Select it, rename it if you want to, Click ok
Now select head. (to be sure)
Goto Object
Submenue opens
Click "Spawn Morph target"
A menue opens
Give your morph target a name.
Click OK
A new dial is now in the head parameters.
ice-boy ( ) posted Tue, 15 February 2011 at 10:09 AM
vilters i am asking how to save morphs so that i can realese them for free.we can not realese OBJ .
ice-boy ( ) posted Tue, 15 February 2011 at 10:10 AM
ok here is the first test. try it out and tell me if it works.
http://www.renderosity.com/mod/freestuff/details.php?item_id=63418
