Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Hi Uwe... I just downloaded (just out of interest, as I use Poser Pro), and although the folders are all there, the UserDefined folder is empty. Is this just me, or the same for everyone I wonder? I'm on Mac, which expands the zip file automatically. (Never had problems with zip files before).
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
How to use it? If you go in the material room, select the material you want to change. Go on "User Defined", select GC for the first kind of conversion. Everything in the Diffuse color channel and the specular color channel will be connected with the proper nodes of the shader.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
-"Amazing
Grace" Hopper
-"Amazing
Grace" Hopper
Comments, suggestions, praise and critique welcome.
-"Amazing
Grace" Hopper
Very cool, Uwe. I tried it out and it works great.
One small glitch - the zip file folder contains "runtime/python/posescripts" instead of "poserscripts" - the letter "r" is missing. This caused me some confusion after installing because the wacros didn't show up.
Path fixed and reuploaded, now everything should be fine. (hopefully)
The wacros are in my freestuff as well. I will add the explanations made here to the zip as well this weekend, so that the people won't need this thread for it.
I hope that helps getting more people into using GC. Both shaders make things a lot easier, and works easily with most materials already there.
The script will do nothing if Alternate_Diffuse is already used. So starting it a second time won't do anything - and it won't try to gamma-correct VSS skin shaders.
-"Amazing
Grace" Hopper
Neither Poser Pro nor Poser 7 on my Mac can see the files unless they have a small "p".
Being a bit obsessive, I renamed the downloaded files without thinking before installing them, so I missed this problem!
what I should be."
Murakami)
Another glitch which I missed, mainly because I don't have a Mac and Windows doesn't care.
Ok, fixed, and made a note for possible later scripts.
-"Amazing
Grace" Hopper
Shouldn't be that much of a hassle. I will look into it next weekend.
-"Amazing
Grace" Hopper
Very impressive work... vielen Dank, Uwe. This saves me doing all this by hand, copying and pasting nodes...
The diffuse value is already reduced by the wacro. Of course you still may have to fine-tune the shader.
-"Amazing
Grace" Hopper
Uwe, may I create a link to this page in my blog? This is a phenomenal tool - using it a lot. And thank you for taking the time to create it.
Of course you may link to this thread. I'm happy that you find it usefull.
:biggrin:
-"Amazing
Grace" Hopper
Thanks so much for that, Uwe. Here's a link to that blog... not a massive readership yet, but one wins by sticking to it:
tightbytes.com/wordpress/
If you see any glaring errors or omissions, please let me know.
I did not find the time up to now. I will see if I manage to do it today in the evening or tomorrow. If that does not work, you will have to wait for another week.
But I think I can do it today.
-"Amazing
Grace" Hopper
Necromancing this.. because.. did that GC with AO wacro ever get created? If so then where? :)
Diffuse_Value on the Diffuse node, which from the screen shot above I'm guessing is GC5_Diff.
Attached Link: http://poser.maredias.de/cg_wacros.zip
Since I found it to be too much work to apply all GC nodes from hand, I made a Wacro for me to do this. As I wanted to publish, I saw a new GC correcting shader from BB, which handled Specular in a different way. I liked what I saw, so I made a script for this as well.Just download the ZIP and unpack it in your Poser directory - must be the main Runtime, or the scripts won't show up. Handling explained in the next postings.
-"Amazing Grace" Hopper
