Sat, Jan 11, 8:50 AM CST
Subject: Ned help:-) Aiko 4 and Stephanie morphs don't inj in V4. suddenly?
Mariny ( ) posted Thu, 17 February 2011 at 2:55 AM · edited Sat, 11 January 2025 at 8:39 AM
Hi:-)
Hope someone can help:-)
Suddenly I don't get Aiko 4 and Stephanie morphs injected to V4??
I open V4.2 base as usual.. Inject her base and morphs ++ from the pose folder..
After that I click Aiko 4 base and don't see any dials in the parametersd for Aiko??
The same happens when I try Stephane too??
I downloaded yesterday V4 complete package from DAz and tried to re-install.. But still don't work?
It's strange after many years with Poser, and I know how to do this:-))
Mariny:-)
Mariny ( ) posted Thu, 17 February 2011 at 3:09 AM
Now I tried it in Poser 8 and it works??
BUT not in Poser Pro 2010??
I always use poser pro 2010 and just tested it now in poser 8..
WHY does it not work in Poser Pro 2010?
WandW ( ) posted Thu, 17 February 2011 at 7:01 AM · edited Thu, 17 February 2011 at 7:08 AM
Are you using the same V4 Runtime in both programs?
If you are not, you need to run the .bat files in Runtimelibraries!DAZ (assuming you are on Windows) in the runtime PP2010 uses.  If they are using the same runtime, try it anyway.
Mariny ( ) posted Tue, 22 February 2011 at 3:11 PM
I have V4 on an external drive and on my harddrive where my poser pro is..
Shall I just use V4 where the poser is and not on an external drive at the same time??
wolfie ( ) posted Tue, 22 February 2011 at 3:55 PM
Depends on where and how you installed stuff.
V4 has an expandable CR2.  That means it loads other scripts that load other scripts.  When you buy A4, it adds new scripts to the Runtime/Libraries/!DAZ folder.  There are BAT files that run a program that scans for these new scripts and adds them to the loader that the CR2 calls.  These scripts contain the empty dials that the INJ files need to put the deltas into.
Dispite what the installer says, you don't have to load them in the poser main folder.  But you do need to install them all to the same runtime, be it the internal one for poser or an external one.  All the V4 figs need to install to the same runtime.  That includes V4, G4, A4, and S4 as well as NPM and NBM.  Then you run the bat file that rebuilds the loader script after each install.
It will NOT work if you install V4 to one runtime and A4 to a different runtime.
I use Poser Pro 2010 and I have a runtime specifically for the Gen4 figures (V4, M4, etc).  All of my V4 addons (V4, G4, A4, S4, NPM, NBM, NGM, etc) are installed to it.  I NEVER install anything to my poser application folder.  V4 runs just fine for me as do all her mutations.
