Tue, Nov 12, 9:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:05 pm)
Subject: Extreme head shake with talk designer
charlesatlas ( ) posted Wed, 16 February 2011 at 9:01 PM · edited Fri, 18 October 2024 at 4:34 AM
Hello
I am using Poser Pro 2010 and the talk designer.  I make a speech file and import it..I notice that when it plays the head will move randomly around and sometimes shake rapidly.  How do I make this so the head doesnt move....thank you.
lesbentley ( ) posted Thu, 17 February 2011 at 3:37 AM
I have never used the talk designer (still on P6), so I have no idea how to prevent the problem, but you should be able to fix it after the fact by editing the head rotatoins in the Graph Editor, and smoothing out any spiky bits. If you don't want the head to move at all, you could force the limits on the head rotations before you do the talk designer thing, or delete all the rotation frames from the head after running the talk designer, and perhaps add a bit of movement back in manually.
charlesatlas ( ) posted Thu, 17 February 2011 at 11:43 AM
Okay will try those things and get back to you.  Thank you.
