You can only upload small files to the forums, it might be better if you send it in an e-mail. I'll send you my e-mail addy in a PM and you can send it over. I'm off to bed now though so it wouldn't be until tomorrow before I look at it. Maybe someone else will help before then.
Sending you a PM now.
Injustice will be avenged.
Cofiwch Dryweryn.
Ok, you're doing it wrong, sorry...
Here's what you need to do:
Load a terrain, right click on the terrain and pick "edit object"
Then click on the "reset terrain" button on the left hand side of the terrain editor.
Lower down, you should see an icon for loading a picture, click on that and navigate to your DEM file and load it.
Click OK and you're done, you should see the same as mine.
Cofiwch Dryweryn.
What happened when you clicked Ok to load the picture then?
I can't see that you missed anything, you should have had the same result as I had above.
Once you've laoded the image, the terrain should be as the image.
Can you tell me how you loaded the image then?
Cofiwch Dryweryn.
I'm at a loss to explain why that is happening, you should be getting what I'm getting, weird.
I don't know what else to suggest at this point..Sorry.
I could maybe make the terrain for you and save it and send it to you if that's any good, let me know what size terrain you'd want if you want to do that.
Cofiwch Dryweryn.
I tried one last thing too. So the combined .dem is made from 4 separate dem files and stiched together in 3dem. I tried loading each individual dem into vue and it worked, however, then I am left with 4 separate terrains to edit when I need to edit it as one. Anyway to combine them to make it one, almost like a "join command.?" If this doesn't work I am tempeted to send you the terrain I need, this was the test terrain so to speak to try this method out. The terrain I am in need of is a different part.
Well I am hoping it is just the trail version as I am trying to convince my work to get vue. To convince though I'd like to show them this terrain. Do you know how to combine the dems in vue to edit them as one terrain? Since they import as different ones, and 4 different layers? Btw, I appreciate all the help!
Here'a a link to all the movies that have used Vue in their creation, show this to your bosses, if they're not impressed they must be mad...
Cofiwch Dryweryn.
I am currenlty trying to import .dems from USGS into Vue and having some problems. I am testing vue out so I am using the trial version, if that has anything to do with what's going on. I doubt it because the terrain doe import. Anyway, I gathered terrain data from the USGS Seamless viewer as geotiffs, and used 3dem to convert the terrain data to .dem Then I imported that into vue. I used this tutorial
http://www.cornucopia3d.com/pub/tutorial/USGS_SDDS%20Tutorial.pdf
Problem is the terrain looks great in 3dem and looks like long striations in vue, which I have no idea where it's getting that. The terrain is low lying, a lot of water with gradual hills around it, I was hoping to scale it all up to make it more dramatic. Anyway, hope these images help and someone has an idea. Above is the image from 3dem.
