Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
heyas; for making texture maps, it doesnt matter. for scaling your object to the poser universe, its better to import to poser, scale, and export a 'final' obj for mapping. are you sure it doesn't say [delete]? that's what you press if you want to delete your message. (deleted) shows up after you have done this and deleted your message.
Is it better to take a newly created posable prop made in Rhino with about 30 groups (objects)into Poser then export out again so texture maps can be made in UVMapper. Or can you skip the import export and go directly into UVMapper and then import into Poser for grouping and joint editing? on a side note why is (Deleted) showing up on my questions or replies here in Renderosity?
