Fri, Nov 22, 3:45 PM CST
Subject: background fit
scottl ( ) posted Tue, 01 March 2011 at 12:18 AM · edited Sun, 17 November 2024 at 8:37 PM
For poser7... when I import a background it asks me if i want to resize the window to fit the dimensions......and even though the bg pic is much larger than the size im rendering its always too small. I need to find out how to make the bg pic fit the render or be imported fullsize.
thx
BionicRooster ( ) posted Tue, 01 March 2011 at 12:44 AM
Forum Moderator
Put your BG pic on a Poser primitive, 1-Sided Square, then you can resize it as you wish.
Poser 10
Octane Render
Wings 3D
Replicant ( ) posted Tue, 01 March 2011 at 5:25 AM
In the render menu change Render Dimensions to match the aspect ratio of your window size. Both need to match the aspect ratio of the background you intend to use. So if your bg pic is 1600x1280 for example your window and render dimension should be 800x640. Or 600x480. So long as the bg is a multiple of the render window and render dimensions it'll fit properly.
Expert in computer code including, but not limited to, BTW; IIRC; IMHO; LMAO; BRB; OIC; ROFL; TTYL. Black belt in Google-fu.
scottl ( ) posted Tue, 01 March 2011 at 10:13 AM
cool, thanks, :)
