Mon, Nov 18, 3:24 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
Subject: V4 no eyebrows
thaliagoo ( ) posted Sat, 05 March 2011 at 5:31 AM · edited Mon, 18 November 2024 at 3:20 AM
I have a character that comes with several different maps for different eyebrow colors. No matter what I do, I cannot get her eyebrows to show up-- it's set to visible, all the materials are there. I don't know what the matter is. Please help.
hborre ( ) posted Sat, 05 March 2011 at 7:59 AM
For many advanced users, the advanced section of the material room tells us a lot more what is happeining.  Could you screencap the advanced MR instead of the problem?
RobynsVeil ( ) posted Sat, 05 March 2011 at 8:18 AM
It is set to visible where, in the Mat Room?
In the Pose room, Preview tab, V4 selected, Body Parts -> eyeBrow. Parameters dialogue, Properties tab, make sure Visible is ticked.
Metaphor of Chooks
thaliagoo ( ) posted Sat, 05 March 2011 at 3:30 PM
Thanks for the replies. The "eyebrow" body part is set to visible in the Pose room, same options as you see above in the mat room.
grichter ( ) posted Sat, 05 March 2011 at 4:33 PM · edited Sat, 05 March 2011 at 4:39 PM
If you applied a head morph, the creator of that head morph could have moved the forehead out in Z (not a dial spinner morph but a complete head reshape that calls in an extra file when injected). Select the eyebrow and try moving it in Z. Tip is to make it visable and you should see a band across the forehead. If you only see the corners just forward of the temples then the eyebrow is still buried in the head probably. Have two such characters I use a lot and created a pz2 that moves the brows to where they need to be to be seen.
Edited to add. You might need one of the reveal dials scripts floating around to see the Z translation dial. My V4 Cr2 I use is highly modified by me and I am away on business with some of my poser files. Not all of them so I have no way of verifying if the translation dials are hidden or not in the original V4 cr2.
Gary
thaliagoo ( ) posted Sat, 05 March 2011 at 4:56 PM · edited Sat, 05 March 2011 at 5:09 PM
I didn't apply a head morph, this is just V4. I do see a Z translation dial and it's set to 0. That being said, I don't see any band across the forehead, either.
I tried to see if her eyebrows were buried inside her head, like you said and I made the head invisible. I only saw her eyeballs and gums/teeth then (not eyebrows)
thaliagoo ( ) posted Sat, 05 March 2011 at 5:14 PM · edited Sat, 05 March 2011 at 5:16 PM
OK, I figured it out-- there was something wrong with my V4 base. I reinstalled V4 base and now the eyebrows show up :D
