Mon, Feb 10, 9:26 AM CST
Subject: Vue 9 crashing
arrow1 ( ) posted Sun, 27 February 2011 at 4:51 PM · edited Sun, 09 February 2025 at 7:19 PM
Vue 9 crashes whenever I try to render a preview animation. There are six P4 figures and one SP4 all with textures reduced in size.The background is Tony Meszaros Australian Outback Scene. I have imported the Poser and DAZ figures into Vue and saved them as VOB objects. I do not know what else to do! Am I the only one having this problem? Cheers.
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
MaryHines ( ) posted Wed, 16 March 2011 at 8:51 AM
this may not help much, cause I'm still using Vue 8 Esprit, but just wondering are you trying to save it as .avi ?...if so, instead try saving the animation as png, tiff or gif. I always import my Poser/DAZ mods as .dae, cause the direct Poser imports are too heavy for my OS.
arrow1 ( ) posted Wed, 16 March 2011 at 3:59 PM
Thank you for your reply. My problem is Vue crashing just when I render a preview. I cannot get to the final animation stage. Cheers
MaryHines ( ) posted Wed, 16 March 2011 at 7:56 PM · edited Wed, 16 March 2011 at 7:59 PM
one 'crash evader' trick I've used alot is to not use the 'render to screen', but to use the 'render to main window'  and the 'render to area' option...first save your scene, then turn all of your viewports to wireframe, except for the main window viewport......then open the render options (using the 'render' options from the top menu,,not the timeline 'render' icon) n select the 'render to main window' option, then be sure to click ' save render to disk', and save it as a .gif ...then go to 'render area' and click the box..then click 'ok'....
directly beside the regular 'render' icon in the top menu bar, u'll see another icon on the left..the 'render to area' icon..click it..your curser will turn into a circle but will turn to crosshair when you get to the main window viewport... ..put your curser on the right top corner of the viewport and drag it to the bottom left corner n then let go..then open the timeline render options (just click once) n select the 'render entire animation' option, then in 'channel files', click 'browse ' and save it as .gif(but while saving, I would suggest creating a folder for it).....set the frame rate size prefs...click 'ok'...now go click on the timeline 'preview' icon...even if it crashes or freezes right after rendering, it won't matter alot cause you will have already saved it to disk
hope this helps, but if not, you can try using open gl fixed or software compatibility mode.
arrow1 ( ) posted Wed, 16 March 2011 at 9:56 PM
Many thanks,I will try your suggestion.Cheers
