Fri, Nov 22, 3:04 AM CST
Subject: Skin Material Question?
tchamberlain2 ( ) posted Wed, 16 March 2011 at 9:55 PM · edited Thu, 21 November 2024 at 9:45 PM
I had a question? When I load my puchased character onto the V4 (in Poser), everything comes out ok (the morphs). But the skin mats have lines going through them (on certain parts of the body). Maybe I'm doing something wrong? Is there something you press or set up in the materials room (in poser) to fix the problem and make the lines disappear? Please help me to fit her mats right. I have a picture example attched to this message for you to see. You can see on her sholder the white lines. There are also some on her thighs. I'm pretty sure this is not the first time some one asked this question. Please someone help me! Thank you...
Medzinatar ( ) posted Wed, 16 March 2011 at 10:30 PM
you probably need to turn texture filtering to "None".
There are a number of scripts available to set all nodes at once.
markschum ( ) posted Wed, 16 March 2011 at 10:39 PM
sorry but you will need  a much closer view of them to show on the forum.
Victoria_Lee ( ) posted Wed, 16 March 2011 at 11:09 PM
Quote - I had a question? When I load my puchased character onto the V4 (in Poser), everything comes out ok (the morphs). But the skin mats have lines going through them (on certain parts of the body). Maybe I'm doing something wrong? Is there something you press or set up in the materials room (in poser) to fix the problem and make the lines disappear? Please help me to fit her mats right. I have a picture example attched to this message for you to see. You can see on her sholder the white lines. There are also some on her thighs. I'm pretty sure this is not the first time some one asked this question. Please someone help me! Thank you...
SVDL has a python script found here that will turn off texture filtering for the current figure, the current prop or the entire scene.
It says it's for Poser 7 but I'm using it in Poser Pro 2010 and it works like a charm.
Hugz from Phoenix, USA
Victoria
tchamberlain2 ( ) posted Wed, 16 March 2011 at 11:09 PM
Ok. This is a better view of some of the issues I was talking about. Sometimes, when I move the poser camera close the lines disappear. So, I kept it near the same distance as my first pic. Just more is seen in this picture. Please can someone help me fix these lines to go away?
To "Medzinatar" How do I get to texture filtering options (to change it)?
Miss Nancy ( ) posted Wed, 16 March 2011 at 11:25 PM
it looks like seams.  turn off tex-filtering by clicking on skin area in material room, then going to image map node.  drop shade rate to 0.2.
tchamberlain2 ( ) posted Wed, 16 March 2011 at 11:27 PM
Thanks for the info "Victoria_Lee."
Have a question: When I click the link, on the page that comes up there are several SVDL python script options there (to download). I know I may look silly (right now) but which one is the right one to download from the page? None of them say anything about texture filtering. One says its for clothes. Another for morphs. Is it the first one in the options? I know one of these should work. I just can't tell which one it is....
Medzinatar ( ) posted Thu, 17 March 2011 at 12:10 AM
[ http://www.renderosity.com/mod/freestuff/details.php?item_id=39676](http://www.renderosity.com/mod/freestuff/details.php?item_id=39676)
is link to texture filtering script, is called "Poser 7 Texture Filtering utility"
you change filtering on texture map box as picture
tchamberlain2 ( ) posted Thu, 17 March 2011 at 12:12 AM
I found it Victoria_Lee.
Thank you also Medzinatar and Miss Nancy. Will try now.
tchamberlain2 ( ) posted Thu, 17 March 2011 at 1:02 AM
OH Yeah!!!!! Problem fixed! Thanks to everyone here and those who got me that link!!!
