Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
But it's not an unused material zone. It's used. There are polygons using the material called "default". Assigning them to some other material will make the "default" be unused, that's true. But the real question is - where are the polygons? The OP thought he assigned them all to other materials already.
Its possible I suppose that the mtl file got a material written to it that has 0 polys assigned. Lightwave will assign a material with no polys, but it doesnt write it out to the file.
I have attached a script that will list all the usemtl lines in an obj but you need to edit the filename to point to your file.Rename from txt to py.
Ok, heres a thought, in Poser go into the materials room , and set all materials to transparency 1 except for default. The polys should then be visible and you can use the grouping tool (I think) to allocate them to another material , or you can find them in your modelling program .
The worst situation is to have a polygon inside another part. If it has no effect you can just leave it hidden.
In the modeling program, can you select the default material, and (in polygon mode) select by material?
On a few occasions I have at this point duplicated the still-unseen default material polygons (it creates a new separate object) and then slid the new object away so that I got an idea of what/where the hidden polys were.
Bevelling and extrusion create new polys, and sometimes they are assigned to the default material if the modeling program can't figure out what they're supposed to be.
OSes: Win7Prox64, Win7Ultx64
MacBook Pro OSX El Capitan Ver 10.11.6
