Fri, Nov 22, 5:59 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Vue 9 Complete is S-L-O-W
kenmo ( ) posted Sun, 27 March 2011 at 5:43 PM · edited Fri, 22 November 2024 at 1:06 PM
Hi...
Any performance tweaks for Vue 9 Complete? I'm getting the "not responding" message alot when I'm moving about in the camera display windows... It also happens when I move from the 3D window to the top, front or side... Vue after a while will snap out of the wait state but it sure takes the fun out of Vue...
My computer is an AMD tri-core X3 710 (2.6) with 8 gbs of DDR2 memory. I'm running Windows 7 Home Premium 64 bit version. My Windows Experience Index is 5.8 (according to Control Panel in Win 7)... Video card is a Nvidia GeForce GTS 250 with 1 gb of memory and the latest NVidia drivers...
All other apps work very well with this setup (ArtRage, Corel Paint Shop X3, Photoshop Elements 9, 3D Coat 3.5, Hexagon 2.5, Wings3D, free version of Sketchup 8)...
This is a fresh install of Windows 7 with all the of Windows and Vue updates...
I'm using the following display options in Vue
OpenGL 2.1 (shader 4)
Enable background draw
OpenGL texturing options - apply texture maps to Polygon meshes
I've attached a screen capture of my display settings as well....
Any suggestions or tips?
Thanks kindly
Ken
ShawnDriscoll ( ) posted Sun, 27 March 2011 at 6:15 PM · edited Sun, 27 March 2011 at 6:15 PM
How much dynamic hair is in your scene?  That's the only thing that hangs my Vue when the camera is pointed at some.  My Vue settings are using the default.
kenmo ( ) posted Sun, 27 March 2011 at 6:32 PM
No hair... I only loaded the primitive castle model that is included with Vue. No terrain or atmosphere....
ShawnDriscoll ( ) posted Sun, 27 March 2011 at 6:40 PM · edited Sun, 27 March 2011 at 6:40 PM
I'm guessing you already tried using the OpenGL (fixed hardware pipeline) then to see if Vue is faster.  OpenGL 2.1 (shader 4) requires hyper-technology, which my system doesn't even begin to approach.
kenmo ( ) posted Sun, 27 March 2011 at 6:55 PM
Yup tried the fixed pipeline as well... a little better but not significantly....
Cheers
Jonj1611 ( ) posted Sun, 27 March 2011 at 9:27 PM · edited Sun, 27 March 2011 at 9:27 PM
Increase the max usable video memory.
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
Peggy_Walters ( ) posted Sun, 27 March 2011 at 11:36 PM
Turn down the background draw and plant background draw sliders a bit toward faster. You have them set to max quality.
LVS - Where Learning is Fun!
bruno021 ( ) posted Mon, 28 March 2011 at 2:02 AM
As Peggy said, your background draws are set too high. I keep them about 2 thirds to the right. Also, you can modify the  usable memory to something around 850 megs, yours is set too low, and only lets Vue use 128megs out of your 1gig of GPU ram.
kenmo ( ) posted Mon, 28 March 2011 at 1:29 PM
Thanks folks... I'll try those settings when I get home...
Cheers
Ken
impish ( ) posted Tue, 29 March 2011 at 6:11 AM
I always set the little preview render window to only render on click so it doesn't take over at inopertune moments.
kenmo ( ) posted Sun, 24 April 2011 at 11:21 AM
Ok...seems to be working better now... Many thanks.....
ShawnDriscoll ( ) posted Mon, 25 April 2011 at 1:02 AM · edited Mon, 25 April 2011 at 1:06 AM
In Infinite, I have these two checked on to help things.  Don't know if Complete has them.
