Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Well I've always cleaned my own low pass filters and it's always worked perfectly. Here is a link on how to do it. Have a read of the methods and precautions page, but it's all pretty obvious stuff. I've always just used the first method listed. Although there is no shame in sending it off to the pro's if you are more comfortable with that! Have a good read of the link and see what you think!
Andrew
I had pretty good luck cleaning my Nikon D70 sensor with Iso-propyl alcohol. I believe it was 97%, or reagent grade, which means there is little water. Get it from a druggist. Standard bottles of this stuff is often 40% water and will not work very well. I used lint-free tissues, which still leave lint behind. I wrapped the tissues around a piece of thin wood that I cut myself to be the width of the sensor. This was important. You must swab or clean the entire surface in one pass. If you use a narrower swab, you will always have lint left along the path of the edge of the swab. Use a minimal amount of alcohol on the swab, not dripping! Do not risk getting a flow of cleaner behind the low-pass filter, because then you buy a new camera. Keep replacing the tissue until the sensor has no more lint on it.
Test by shooting up at a clear sky focussed far away and at a very small aperature. Spots will show immediately. Re-clean until you are satisfied, which might take 10 testing/recleaning cycles.
You will really appreciate your next camera with cleaning built into it, as did I. I made a series of 25 small photos with instructions on them describing my entire process, but I can only attach one at a time here, so if you want to send your email adress to me at wordcycling@hotmail.com , I will send the set to you. It totals about 3 MB.
Wayne
I have made the 25 photographs into one PDF file now so I will try to attach that here for those who may be interested. It is just under 1 MB so possibly it may be too large to send to Renderosity. Let's see...
Well, I tried that and it said the file extension was improper so I guess you cannot attach a PDF file. Okay then, if anyone wants it, send your email address to here:
Wayne
Quote - I have made the 25 photographs into one PDF file now so I will try to attach that here for those who may be interested. It is just under 1 MB so possibly it may be too large to send to Renderosity. Let's see...
Wayne
Wayne.
Thank you I received the pdf file that you mailed to me.
I will have a look.
God Bless.
Regards.
Christo.
If you want to upload it as a tut (you can always delete later if you want), when you go to the tutorial tab the option to upload is there. You would use "offsite".
I did post a quick reply about cleaning the sensor but apparently without thinking posted it in the thread on "lens cleaning" on this same page.
If you don't want to spend quite that much, for about half the price you can get a lighted head band magnifier. (Tom probably knows what I'm talking about) I find this a more versatile tool and went this route. (see picture at top)
And you can also get kits with the cleaning solution and a paddle made to the size of your sensor if you don't want to mess with the alcohol and tissues. The kit is a little on the expensive side as compared to the DIY option but again it's easier. Google Photographic Solutions, Inc Professional Digital Survival Kit, they come in version I, II or III. The website will tell you which version fits your camera.
Hope that sheds a little more light on the subject : )
They say a picture is
worth a thousand words...
So where do they go when a photograph leaves you
speechless?
hello... i just bought a second hand Nikon D40 its a very nice camera but a lot of my landscapes are riddled with dots... its a pain... i own a rocket blower but had little effect... whats your oppion on cleaning the sensor?!
cheers
Mike
