Mon, Dec 2, 12:35 PM CST
Photoshop F.A.Q (Last Updated: 2024 Nov 26 6:58 am)
Are you up to the challenge??
Subject: Depth Of Field Effect in Photoshop?
Scar-Crow ( ) posted Fri, 17 August 2001 at 9:31 AM · edited Mon, 02 December 2024 at 10:17 AM
Is there such an effect in photoshop I cant's seem to find it. Or is it under an other name?
dreamer101 ( ) posted Sat, 18 August 2001 at 12:29 AM
Are you talking Perspective? That is found in Edit - Transform - Perspective. Also, there is a Plug-in called Andromeda Perspective Filter v1.1 which can be downloaded.
lundqvist ( ) posted Sat, 18 August 2001 at 4:34 PM
Not quite sure what effect you want to achieve, a common method of faking gradual loss of focus with distance is to make a copy of the layer you want to give the illusion of depth to, Gaussian Blur it to the maximum soft focus you want, apply a layer mask to the blurred layer and draw a black/white gradient into the mask to reveal only as much of the blurred layer as you need. Hope that made sense.
aapasuo ( ) posted Tue, 21 August 2001 at 3:28 AM
If you are trying to make this on a picture made in a 3D Program, you could see if your program supports saving the z-buffer. z-buffer has the depth information of the image and can be used as a mask when using gaussian blur as advised by lundqvist on the previous reply. If you are editing a photograph you have to make the mask by hand as photos don't have depth information.
loneglyph ( ) posted Thu, 23 August 2001 at 3:34 PM
Bryce has a distance mask render option as well. It makes a perfect alpha channel for Photoshop where you can gaussian blur the foreground and background. You can increase/decrease the contrast in this new alpha layer to simulate different focal lengths.
aapasuo ( ) posted Fri, 24 August 2001 at 12:57 AM
You can also select certain areas of the z-buffer/distance masks with Photoshop's "color range". This way you can modify the "camera's" place of focus. For example if you do color range with 50% black (grey) and then invert the selection you can blur only the foreground and the background. The middle area of the image is then maintained in focus.
mugsworth ( ) posted Mon, 03 September 2001 at 10:00 PM
Andromeda Vari Focus plugin
