Sun, Feb 2, 6:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Morphs++ does not work with Aiko
Paradigm6790 ( ) posted Thu, 19 May 2011 at 11:03 PM · edited Thu, 23 January 2025 at 3:22 PM
I have Aiko (and thus Victoria 4) installed, and the morphs++ works fine with victoria, but when I load Aiko I cannot use them. Nor can I manually inject the Aiko morphs into the victoria 4 that CAN use the morphs : /
markschum ( ) posted Fri, 20 May 2011 at 12:17 AM
I dont have a problem loading the V4 morphs to Aiko 4. The eyes seem messed up but I dont use aiko 4 so I dont know if thats normal.
What error do you get ?
Paradigm6790 ( ) posted Fri, 20 May 2011 at 12:26 AM
I don't get an error, the option to change things is not there. All I can do is bend, twist, up/down etc
Jules53757 ( ) posted Fri, 20 May 2011 at 12:43 AM
Check out Victoria and you'll find the Aiko morphs among the others and then the morphs++ will work.
Ulli
Medzinatar ( ) posted Fri, 20 May 2011 at 12:43 AM · edited Fri, 20 May 2011 at 12:45 AM
Sometime init doesn't take after install and no error message is given.  You can try running again from desktop shortcut if there.
or from the command prompt,
(your content folder)/Runtime/Libraries/!DAZ/DzCreateExPFiles-V4.bat
