Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
So I have installed hypervue on my main PC along with rendercow - rendercow also install on my 2nd PC. Both are currently contected to a netgear switch via a gigabite 10/100/1000 network card in each - the on board nic and firewalls have been disabled on each PC and both PC are hooked up to a KVM
Then just when I think I'm getting there-I'm not!
To use Hypervue, select 'External', then click the edit button to the right of it. There is your hypervue manager window.
I did this fine and then I get the following message in a black Vue screen;
*Vue 9 Standalone Renderer Version 9.00 - Build 9005691 *
Initializing...OK
THIS APPLICATION HAS REQUESTED THE RUNTIME TO TERMINATE IN AN UNUSUAL WAY.
PLEASE CONTACT THE APPLICATION'S SUPPORT TEAM FOR MORE INFORMATION
(Sorry for the uppercase)
I also get a small windows like message saying;
A problem caused the program to stop working correctly.
windows will close the program and notify you if a solution is available.
I really dont know what else to try - please help before I throw it out the window!
Thanks
