Community Center F.A.Q (Last Updated: 2025 Jan 22 10:24 am)
The Photography Gallery has reappeared, and all is well.
Commenting continues to be a problem. The error message has expanded:
MySQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '11:30:21, comment_cnt = 14, last_comment = 2011 WHERE image_id = 2208' at line 4, occured in query: "UPDATE gallery_image_stat SET rating = 5.0000, rate_cnt = 10, last_rate = 2011-06-02 11:30:21, comment_cnt = 14, last_comment = 2011 WHERE image_id = 2208648;".
Fatal error: Call to undefined function bw_event() in /rn1/renderosity/public_html/mod/gallery/comment.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code on line 177
Thanks!
Tara
"If your pictures aren't good enough, you're not close enough." ... Robert Capa
The "whats new" option now works :)
The error when pressing the "Galleries" button (an thus NOT selecting one of the sub-options" also still gives an error
Fatal error: Unsupported operand types in /rn1/renderosity/public_html/mod/gallery/index.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code on line 1131
I've been having weird things happen when trying to upload an image. Getting fatal error messages, then my entire gallery disappears. Then comes back again. This happened twice this morning while trying to upload, so I never was able to get anything uploaded. Thought I try tonight and it's telling me I have exceeded by daily quota, which I haven't because it never uploaded the image. Oh well, guess I'll give it a go tomorrow. Carol
Sorry to bother you again so soon, Stacey! I've got a couple of glitchy things for you and the band to look into ...
I'm browsing the galleries this morning, and everything works just fine except the Photography Gallery. When I got to that one, instead of the gallery page I got the header section and the following error message:
Fatal error
: Unsupported operand types in /rn1/renderosity/public_html/mod/gallery/browse.php on line 527
Second issue: When I post a comment this morning I get the following error message:
If I hit the "back" button and click the comment button again, I get the standard RR screen that says:
You have already commented on this image and cannot comment twice.
When I go back and check the image, and the comment is there. So I can comment, it just takes a couple extra steps.
Thanks in advance!
Tara
