Thu, Jan 23, 11:30 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: poser animation question....any advice please.....
homeriscool ( ) posted Mon, 06 June 2011 at 6:33 PM · edited Thu, 23 January 2025 at 11:14 PM
hi everyone, thanks for taking the time to read this. my problem is i have imported my home footage of my son playing in a field and he wants me to put a helicopter hovering above him ( which i have ) but i would like to be able to remove the imported avi home video while rendering my basic animation. is there anyway i can do this? sounds rather silly, but i will be doing further work on it, and adding special effects, so i do have my reasons.....
thanks in advance
oldgreycat ( ) posted Mon, 06 June 2011 at 7:09 PM
After working out whatever motion you want with the video footage in place, remove it and select a color (green is common) for the background - render, save, then import into whatever video editor you use and combine the two there.
Miss Nancy ( ) posted Mon, 06 June 2011 at 8:39 PM
is also possible to save series of tiffs with alpha channel with nothing behind them, then concatenate, then that is layer 0 above layer 1 (home video clip), depending on video editor.
homeriscool ( ) posted Tue, 07 June 2011 at 3:31 AM
Quote - After working out whatever motion you want with the video footage in place, remove it and select a color (green is common) for the background - render, save, then import into whatever video editor you use and combine the two there.
thanks for the reply and this is exactly my problem - how do i remove the imported video and keep my animation in place......
markschum ( ) posted Tue, 07 June 2011 at 6:49 AM
Put the background on a square prop, scaled to fit. Then when your copter is animated , delete the prop square.
