Tue, Feb 4, 8:50 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: debugger for PoserPyhton
pauldol ( ) posted Sat, 11 June 2011 at 10:09 AM · edited Tue, 04 February 2025 at 8:41 PM
Hi all,
I am using Poser8 and pyhton.
I was wondering if there is a way to use a debugger for python.
By default, Poser offers the Poser Python Shell. does this have a debugger???
otherwise I was thinking of using the standard python debugger.
However I would first need to load all the libraries and modules that poser pyhton shell uses as well..
Any ideas on what to do?
Thanks,
Paul
markschum ( ) posted Sat, 11 June 2011 at 5:43 PM
I have never done anything complicated enough to need a debugger. I do tend to use a lot of print statements to see what the variables contain if its not doing what I want.
I have no clue on using a debugger in poser.
nruddock ( ) posted Sat, 11 June 2011 at 7:24 PM
pauldol ( ) posted Wed, 22 June 2011 at 9:34 AM
Quote - See -> http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2786642
and -> http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2798222
You also need to take great care when trying to debug callback functions.
great.
thank you,
paul
