Sun, Jan 26, 10:26 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Small bug with Swaptotal
Roy G ( ) posted Sun, 12 June 2011 at 2:53 AM · edited Sun, 26 January 2025 at 12:18 AM
Hello Python gurus.
I'm having a small problem using Ockhams very usefull "swaptotal" script in Poser 2010. Which can be found here.
http://www.renderosity.com/mod/freestuff/details.php?item_id=17222
Ockham doesn’t have Poser 2010, so he can't really help since he is still using Poser 8. He suggested that I try here.
What happens is the script seems to hang. It hangs until I select a different body part and then the new pose snaps on.
After loading a fresh character and then trying the script again it worked correctly once. Then I would have to once again select different body parts to force the script to finish.
It's not a huge problem, since I now know the workaround. But is there a simple fix?
Dizzi ( ) posted Sun, 12 June 2011 at 7:05 AM
Well, Poser does not update the preview on its own after the script execution, so a "scene.DrawAll()" as last line in all of the scripts should help.
Roy G ( ) posted Sun, 12 June 2011 at 11:35 AM
That did it. :)
Thanks a bunch
