Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
under cameras they are listed as shadow cams
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
If you need it pointing at something in specific, select the light, then go to object point at.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Keep in mind that a ShadowCam's actual function is to calculate the position from which shadows will be cast, and that the ShadowCams CAN be translated and rotated away from their light's actual position or point of view.
Make sure the ShadowCam is zeroed if you are trying to see what the light will hit.
Can you look thru the lights in poser to see where they are pointing?
MacBook Pro OSX El Capitan Ver 10.11.6
