Sat, Feb 1, 5:31 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 28 1:01 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: How to "de-Subdivide" a mesh?
ErickL88 ( ) posted Thu, 16 June 2011 at 11:39 AM · edited Sat, 01 February 2025 at 5:26 PM
Within Blender 2.49b, I know now, how to select a bunch of polys and how to subdivide them later on, to make the mesh more dense.
But how can I do the opposite?
Like .. when having a dense mesh, that just stays in the far back, or will be blurred out due usage to DOF, or where there simply is no need for a big poly count, how can I reduce the it, or kind of "merge" a batch of ploys together, to a bigger cluster?
The goal would be, to save a bit of recources, and/or to use them where it's due.
Kinda stupid question, but as a very beginner, the whole programm and it's UI is pretty much confusing LOL
Thanks in advance.
Warlock279 ( ) posted Thu, 16 June 2011 at 1:48 PM · edited Thu, 16 June 2011 at 1:51 PM
Well, one way to do it is to turn off your subdivion modifier, or reduce the number division in it. [Assuming you've not gone ahead and applied it permanantly]
Another is to actually use a whole new version of the mesh called an "LOD" [level of detail] model that gets swapped in as the object gets further away from the camera. Its not uncommon in some cases to have three or four of these for an object, set to be used for varying distances.
The LOD's can be created a couple different ways. Either completely remodeling the mesh the way you'd retopo a high poly sculpt to a production level model, or using a polygon reducton tool. In Blender there's a modifier called "Decimate" that'll do what you're looking for, tho be warned, any automated polygon reduction tool has the potential to make an complete mess of your mesh.
This is kinda general, but hopefuly it gets you on the path you're looking. :)
Core i7 950@3.02GHz | 12GB Corsair Dominator Ram@1600mHz | 2GB Geforce GTX 660
Lightwave | Blender | Marmoset | GIMP | Krita
ErickL88 ( ) posted Thu, 16 June 2011 at 2:43 PM
Thanks for the answer!
That'll keep me occupied for a while. =)
thewebflea ( ) posted Thu, 16 June 2011 at 8:26 PM
Use the Desimate modifier
Me no like cause it makes object look ugly .. but fir what yu wanta do ... its the way to go
DramaKing ( ) posted Fri, 17 June 2011 at 10:56 PM
I haven't tried to do this since 2.49, but I think I used some PolyReduce script or similar. I would hope that Decimate would give better results, but it does know exactly how to remove polygons properly, and it can give some strange results. I thought I remembered there being a retopo tool, too. The best way, I think, is that when creating subdivisions is to use the Multires modifier and only apply it when needed or finished modeling. This way use can easily change the resolution of a mesh.
It is better to do one thing well, than to do many things and excel at nothing.
Cybermonk ( ) posted Sat, 18 June 2011 at 5:38 PM
If nothing else you can retopo the thing using the snap to surface. Here's a good tut http://www.youtube.com/watch?v=HVwa9Xk3_dE. Also if you decide to use the decimate modifier... If you cut your model in 1/2 and then decimate, then mirror... it will preservere your center line.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
