Tue, Feb 18, 12:00 AM CST
Subject: Merge objecs as a unique object
egalps1 ( ) posted Tue, 21 June 2011 at 7:26 AM · edited Fri, 07 February 2025 at 2:36 PM
I ve created a scene in vue.In fact it is a piece of ground consists of the terrain and the different spieces of plants i ve put on it.Now i want to make all this as a unique object.Is there  a way?Thanks
Cosme..D..Churruca ( ) posted Tue, 21 June 2011 at 8:40 AM
First, excuse my english. I do that  marking the objects in the object browser, click on edit object and then click on "weld". thats all. I dont know if there is another way, for me this one works most of the times. It dont work with booleans.
bruno021 ( ) posted Tue, 21 June 2011 at 8:55 AM
Welding only works  when using .vob or other imported 3d objetc that appear as groups in the World browser. Why would you want to group all objects in your scene?
egalps1 ( ) posted Tue, 21 June 2011 at 11:18 AM
Quote - Welding only works  when using .vob or other imported 3d objetc that appear as groups in the World browser. Why would you want to group all objects in your scene?
Dear bruno
Thanks for the answer.In fact i  have created a piece of ground as the one that you have on your profile picture (with the cow).However it s a small piece.Now i want to use it on another scene but to cover  the whole environment on this scne i need to have this piece more than one time.That s why i need to group all objects
bruno021 ( ) posted Tue, 21 June 2011 at 3:51 PM
Ok, I see. You can group all objects using the Ctl+G command (PC), but this won't make it one object, yopu wont be able to save it as .vob, for example. So you want the group to be duplicated on a new scene? It will be the same group of objects all over a new scene? You can simply group all your object and duplicate them in the existing scene, no need to open a new scene for this. You can also save this scene, and merge this scene with another one using the File, merge command.
