Forum Moderators: RedPhantom
I am working on a large number of similar animations. I just noticed that the animations which have the lights moving were all saved on the last frame (it's a project where clips have to match up together, so I am rendering beginning or end frames for comparison). The clips that were saved on the first frame don't have the moving lights. I could turn lights animating off, but now I'd have to do it for every clip, and it's quicker to just re-load correct lights. I should definitely have done that when creating the initial scene though.
I've got a number of animations and I am continually finding and fixing the same problem: my lights change settings over the course of the animation. When I created the scene I locked all of the lights. The first time the settings changed, I created a single frame light-set from the first frame to apply to the end frame. For some reason, it changes the lights on the first frame also, and so I apply it there as well. When I then scrub the animation it looks fine. But whenever I load an animation to create a new one from it, the lights will often do it again, seemingly randomly (but always the same changes). I have a number of clips, and the frequency with which I am seeing this happen goes way beyond what I would expect if it were a simple oversight with just one clip. It really seems like any of my clips may just suddenly revert back to this behavior, and I can't figure it out.
