Tue, Nov 19, 5:04 PM CST
Subject: Executable file broken?
devilfish36000 ( ) posted Sun, 03 July 2011 at 5:14 PM · edited Thu, 08 August 2024 at 5:21 AM
Basically my poser pro 2010 has stopped working. It loads up freezes, then displays the error message Shown above. I tried reinstalling it, and i have tried updating flash and my video driver, but nothing is working.
Any help would be greatly appreciated
Thanking you in advance
markschum ( ) posted Sun, 03 July 2011 at 6:02 PM
OK, what operating system , and where did you install it to ? (what folder)
Try right clicking on the exe file and select Run as Administrator if its a new install.
devilfish36000 ( ) posted Sun, 03 July 2011 at 6:18 PM
It stays open now thanks
But now i have the problem of an error message saying
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032" errorID=2032]. URL: http://www.contentparadise.com/api/search_params.aspx"] messageId="167360A5-F63D-1727-CB59-FCDF66F1505B" type="fault" bubbles=false cancelable=true eventPhase=2]
Any ideas?
BTW I'm runnning windows vista and have save the exe file in
C:Program FilesSmith MicroPoser Pro 2010
hborre ( ) posted Sun, 03 July 2011 at 6:30 PM
Online Now!
That is where some of your problems may occur.  Both Vista and Window 7 have the UAC feature which prevents any write backs into that particular folder.  Suggest you reinstall PP2010 into a separate folder on your main drive to offset the interference.
devilfish36000 ( ) posted Sun, 03 July 2011 at 6:34 PM
Should I uninstall the one in the SmithMicro folder?
hborre ( ) posted Sun, 03 July 2011 at 8:29 PM
Online Now!
Advisable.
devilfish36000 ( ) posted Mon, 04 July 2011 at 5:16 PM
Have just uninstalled the original file and reinstalled into a brand new flder, am still receivig the error messeag
markschum ( ) posted Mon, 04 July 2011 at 6:28 PM
That error is Poser trying to contact ContentParadise. I think you can ignore it.
devilfish36000 ( ) posted Tue, 05 July 2011 at 8:04 AM
Unfortunatel none of my libraries appear, it just goes blank after the message, meaning i cant use any content
Plutom ( ) posted Tue, 05 July 2011 at 8:37 AM
Devilfish, sometimes that will happen to me and I don't know why, but if I take action to go online, everything starts working.  Poser is not searching for anything and I'm not an expert, but it works at least for me and every time.  Something, gets a kick when my modem is activated.  Doesn't even have to go all the way through to my IP.  I have a 56K Modem.  Jan
devilfish36000 ( ) posted Tue, 05 July 2011 at 10:47 AM
Managed to fix the issue by running as admin then reinstalling flash.
A big thanks to everone who went out of their way to help me
Plutom ( ) posted Tue, 05 July 2011 at 10:57 AM
Thanks for your feed back, so Flash was the bad boy here DF.  Jan
