Community Center F.A.Q (Last Updated: 2025 Jan 06 7:21 am)
Never mind - the product actually spells "MB4 Cheynne", so that explains it in this case.
Maybe "abnormal" product names is the reason for the other search problems as well, I don't know, LOL.
Tried to delete the post BTW, but can't find any Delete or Edit options, despite the forum says "You can edit and delete your posts"?
Edit: well I can Edit or Delete this reply, but not the initial post?
Quote - Tried to delete the post BTW, but can't find any Delete or Edit options, despite the forum says "You can edit and delete your posts"? Edit: well I can Edit or Delete this reply, but not the initial post?
Editing is only possible within a short period after posting, deletion has the same time constraint, and I think becomes impossible once a reply is made.
Mods are not subject to these constraints.
I don't think the Store Search works very well. For example, if you search on "MB4 cheyenne", it will find that exact product. But if you just search on "cheyenne", nothing shows up at all. If it worked well it would show "MB4 Cheyenne" as well as any other product with "cheyenne" as part of the name.
I've seen many other similar cases.
