Fri, Nov 22, 6:11 PM CST
Subject: Is there any way to make a "foot camera"?
Cyberwoman ( ) posted Tue, 05 July 2011 at 3:51 PM · edited Fri, 22 November 2024 at 6:05 PM
I'm working on a pair of shoes in Poser Pro 2010, and it would be really nice if I had something like the Poser Hand Camera/Face Camera, except it revolved around the figure's foot instead. Does anyone know if there is a way to set up a camera to revolve around an object like that? I tried using the "Point At..." command on a dolly camera, but all that did was create a camera that was extremely counter-intuitive and slow to move.
~*I've made it my mission to build Cyberworld, one polygon at a time*~
Watch it happen at my technology blog, Building Cyberworld.
CyberDream ( ) posted Tue, 05 July 2011 at 4:11 PM · edited Tue, 05 July 2011 at 4:13 PM
You should parent the camera to object instead of "point at"
Rance01 ( ) posted Tue, 05 July 2011 at 4:28 PM
Point At using the Main Camera (Poser 7) seems to work fine.  Not sure about the Aux ... The Dolly Cam doesn't work the same as other Poser cameras.  I think moving the camera also moves the axis.  Try using the Main.
Best Wishes,
Rªnce
Rance01 ( ) posted Tue, 05 July 2011 at 4:30 PM
Sorry, using the Aux Camera DOES work.  Had a bit of a glitch when I first tried to test it.
-R
Cyberwoman ( ) posted Tue, 05 July 2011 at 4:41 PM
"Point At..." with a revolving camera (e.g. the Main Camera or Aux Camera) worked perfectly!
Thanks a million 😄
RedPhantom ( ) posted Tue, 05 July 2011 at 7:15 PM
Site Admin Online Now!
You could also create a new camera and use that as a foot camera (maybe a left and right one) and leave the main cameras to check how things look at a distance
