Sun, Jan 26, 6:49 PM CST
Subject: Are Python Scripts for Mac or Windows?
attilako ( ) posted Sat, 09 July 2011 at 4:13 AM · edited Sat, 25 January 2025 at 5:44 PM
I tried many of Ockham's python script but none is working perfectly on my
Poser 7 Mac.
For example when I use the script "Snap to" Poser crashes when I save.
With another script called "Find this" I get the message:
"Traceback (most recent call last) :
File "/Application/Poser 7/Runtime/Python/poserScriptsMenu/Utility/FindThis.py" , line 117, in ?
CenVecAngle - CenVecAngle - CamVecAngle
NameError: name 'CamVecAngle is not defined
Are you able to run Ockham Scripts perfectly?
http://www.ockhamsbungalow.com/Python/
Thanks
Attila
millighost ( ) posted Sat, 09 July 2011 at 4:57 AM
Quote - ... With another script called "Find this" I get the message:
 At least with this error, i can see that the script will not run correctly when the yOrbit value of your current camera is 0. Which has nothing to do with running on Mac or PC. I did not try the other scripts, but unless the scripts do something with filenames or so, they should work more or less the same.
markschum ( ) posted Sat, 09 July 2011 at 10:05 AM
Mac had a problem that they did not support TKINTER so some scripts using TK for an interface just did not run on macs. Other wise everything should work the same.
have a look in the script or where camvecangle is first used.  Thats where the error is occuring.
attilako ( ) posted Sun, 10 July 2011 at 3:02 PM
Thanks for the info. I'll try to examin those scripts which don't have TKINTER in it
