Tue, Nov 12, 6:23 PM CST
Subject: Poser Environments - Landscapes?
Risus ( ) posted Sun, 26 June 2011 at 4:29 PM · edited Sat, 09 November 2024 at 7:39 PM
Hi everyone, I know there are plenty of existing sets for Bryce, Vue, Carrara, etc. but are there any nice outdoor Poser sets with open meadows or valley lakes,  that sort of thing with pretty and open landscapes? I'm looking for something similar to:
http://www.daz3d.com/i/shop/itemdetails/?item=8138
http://www.daz3d.com/i/shop/itemdetails/?item=8052
http://www.daz3d.com/i/3d-models/-/carraras-bmf-landscape?item=8929&spmeta=ab
Any suggestions would be appreciated!
LaurieA ( ) posted Sun, 26 June 2011 at 4:40 PM · edited Sun, 26 June 2011 at 4:43 PM
Poser unfortunately isn't conducive to great looking outdoor scenes. You can however check out TerraDome packs at Runtime DNA. PZ3 files can also be opened directly in the most recent versions of Vue which does do awesome landscapes.
icprncss2 ( ) posted Sun, 26 June 2011 at 5:05 PM
RDNA's Microcosm is in their deep freeze sale for less than $6.  There are a great many addos for it both in the their freebie section and in their Real Deals.
Textures for Microcosm can also be used on the IC3 ground and water planes.
Believable3D ( ) posted Sun, 26 June 2011 at 6:18 PM
I don't think it's likely you're going to get products for Poser that on the order of the Carrara, Bryce and Vue ones. There are however a few sets that are usable, depending on what you're after (e.g. Terradome etc mentioned above; Fober's The Lake set at Daz)... if it's in the far background it may not be too bad. And there are also things you can add in (trees, plants) to make the foreground a bit more believable.
On the whole though, if you want to do outdoor stuff in Poser, most of the really good quality work is for city scenes (or futuristic), at least as far as I've seen.
______________
seachnasaigh ( ) posted Sun, 26 June 2011 at 7:14 PM
     Bryce and Vue are inherently better at outdoor scenes, but if you are working in Poser, than an environment model is very handy.  I'm a bit surprised that Poser doesn't include one.
     To whom it may concern...
     Doesn't help you right now, but for future reference, I'm working on what will be a freely-distributable Poser environment which is optimized for P8+ and which is big enough to provide a setting for my cottages, Lothlorien trees, and elvish sailboats.  Some of the terrains will be forest, some will have streams/rivers running through them.
     It is a dome-covered "tank" style, but much larger and taller-proportioned than the Millennium Environment.  It won't have the two layers of transparency on the walls (that bogs IDL down), and the juncture of the terrain and the wall will be a gradual segue which will exploit Poser's node material system.  This shows a cottage and Aiko 3 for scale.  I'm also making some modest-poly trees which avoid use of transmapping (IDL consideration again), for populating the foreground.
seach's enviro
     I will provide instructions for those who have Bryce, Vue, et al on how to make panoramic renders to re-texture the walls, at each of its standard scales.  Both freebie and commercial texture packs would be welcome.  I have Vue 9.5 Infinite and plan to make some wall textures myself.  ^^
     The modeler screenshot shows a Millennium Environment on the left for comparison.
Believable3D ( ) posted Sun, 26 June 2011 at 7:35 PM
Good idea, seachnasaigh! I think I'd still like something like that to be a bit bigger yet, but I suppose it depends on the user's needs....
______________
Believable3D ( ) posted Sun, 26 June 2011 at 7:43 PM
It should be added that the newfound ability to export to a nonbiased renderer like Lux adds intriguing possibilities. Even if Poser isn't really up to dealing with landscape rendering, maybe setting up a nice landscape scene in Poser and rendering in Lux will get good results, and there will be more use for good landscape models. (I suppose it depends somewhat on cost/benefit ratio. If it's gonna take a zillion years to render a decent landscape scene in Lux, people will stick with something like Vue etc, I expect....)
______________
seachnasaigh ( ) posted Sun, 26 June 2011 at 9:13 PM
(Believable3D)
Quote - Good idea, seachnasaigh! I think I'd still like something like that to be a bit bigger yet, but I suppose it depends on the user's needs....
Thank you, Believable3D.  ^^
       that is size 1; there will be two larger sizes also. *
Believable3D ( ) posted Tue, 28 June 2011 at 11:35 PM
Above when I commented on the superiority of urban scenes for Poser compared to landscape scenes, I was thinking of a few artists, but especially of Stonemason. Turns out I was unaware of his Enchanted Forest set (on sale right now): it looks absolutely amazing....
http://www.daz3d.com/i/shop/itemdetails/?item=11998&trid=427287546
______________
Risus ( ) posted Mon, 04 July 2011 at 11:31 PM
Thank you everyone for your replies! I know that unfortunately, Poser isn't as ideal for outdoor scenes like that. I've been doing tons of darker lit scifi and dystopian scenes, which it works well for. But I'll check out your suggestions and continue to keep my eyes open for nice outdoor sets!
estherau ( ) posted Tue, 05 July 2011 at 7:37 AM
 LaurieA, poser imports beautifully into vue, but often I will just creat an HDRI image with spherical map in vue and then I will map it to the BB envirsphere which works beautifully.  Also one can buy lots of great outdoor HDRIs if one doesn't have vue eg from safeharbor.
Love esther
MY ONLINE COMIC IS NOW LIVE
Ometeotl ( ) posted Sun, 10 July 2011 at 6:45 PM
@seachnasaigh: Oh my, this looks wonderful and is exactly what I've been looking for since I discovered DS / Poser! Can't wait to get this beauty in runtime (c:
seachnasaigh ( ) posted Sun, 10 July 2011 at 10:26 PM · edited Sun, 10 July 2011 at 10:33 PM
Attached Link: Lothlorien terrain - Poser test
Thank you, Ometeotl.  :)   The hotlink above is to a render test of one of the large sized terrains (no walls yet);  notice the same A-frame cottage in this scene.  The footpaths are added by drawing them on a layer of a discriminator image;  the muddy streambanks, grass, and paths are one material zone.  The paths can be easily changed to fit your own placement of items in the scene.  The lights are IDL emitters and work automatically, so to speak;  you don't need to juggles hundreds of Poser lights.  This render used just the three default lights, and they were turned way down.
     Oh, speaking of render tests, this was a material test render for pixie dust.  The Posette pixie is scaled way down and will just be a wee small detail in the scene, but when I saw this mat test render, I let out an audible "Ooooooh!"    I really like it, and it's only four nodes, and you don't even need to UV map the dust trail mesh.  ^^
pixie dust!
I'll raust up a screenshot of the material room when I get a chance.
3Dave ( ) posted Mon, 11 July 2011 at 11:31 AM
Did anyone mention this one?
http://www.sharecg.com/v/39996/related/11/Poser/The-Hills-environment-for-DAZ-Studio-&-Poser
SteveJax ( ) posted Mon, 11 July 2011 at 11:39 AM
Nobody has mentioned Stonemason's Enchanted Forest?
Believable3D ( ) posted Mon, 11 July 2011 at 11:57 AM
Yeah, see my Jun 28 post. Still wishing I had bought it when it was 50% off, but am short of $$$.
______________
cspear ( ) posted Mon, 11 July 2011 at 2:49 PM
You can make pretty good landscape scenes in Poser - at least in P8 and PP2010 - as long as you're not too ambitious. It's not that you can't do scenes with loads of trees and plants, atmospheric effects and water features in Poser: you can, as long as you don't mind spending ages placing them all and can accept render times of several hours, or indeed days.
Here's a scene I'm working on, rendered in PP2010 with IDL and GC on. There's a single infinite light.
I used RubiconDigital's Poser Sky Generator (available in the Marketplace) which uses procedural shaders to generate all sorts of skies+clouds - it takes a bit of getting used to but it's really good  once you've figured it out.
The foreground landscape element is 'Versatile Terrain' from DAZ, and there are two instances of First Bastion's Rolling Plains, also at DAZ (which is arguably more versatile than the former), further back.
The village and Land Rover are items from years and years ago from somewhere, I really can't remember if they're freebies or purchased. And there's the DAZ sheep and lamb and M4.
There are only two trees in the scene, the nearest by Flink and the one just behind the buildings from Rose Rouge by Powerage, both available here. The forest behind the first set of hills is a curved plane with a stock shot and corresponding transparency map applied: a very cheap-to-render solution with the drawback that it has to match the scene lighting!
In PP2010 you have the option to generate Z-Depth and Position maps, and these can be used to generate depth of field, distance haze, weather effects etc. in postwork.
As you'll see from the screen grab, it's not an immersive environment and there's little leeway for camera movement, so forget sweeping vistas and animations.
If you want to do more ambitious things you really need Vue. I've no idea how good Carrara is, nor what the current state of play with Bryce is.
PoserPro 11 - Units: Metres
Adobe CC 2017
SteveJax ( ) posted Mon, 11 July 2011 at 6:28 PM
Quote - Yeah, see my Jun 28 post. Still wishing I had bought it when it was 50% off, but am short of $$$.
My bad. I was reading when I just woke up and must have scrolled too fast past that one.
seachnasaigh ( ) posted Mon, 18 July 2011 at 1:05 PM
Attached Link: Poser terrain, size large, full size view
That's good work, *cspear*.  ![](http://www.renderosity.com/mod/forumpro/art/emoticons/thumbup.gif)
     Progress update:  This is one of the large terrains for the Poser enviro set.  Where the waterplane turns red indicates area outside of the walls.  In that red area, I'll make an outer terrain which mates up to the inner terrain.  The purpose of the outer terrain ring will be for Vue owners to make 360 degree panoramic renders with which to texture the terrain walls.
Poser enviro terrain, size large
     For scale, there is an Aiko 3 standing beside a Celtic cross at center (0,0).  There's another Aiko 3 on one of the bridges, and there are some low-poly cottages on a plateau.
ima70 ( ) posted Mon, 18 July 2011 at 3:36 PM
Nobody mentioned RDNA Terradome and its addons
http://www.runtimedna.com/Runtime-DNA-s-TerraDome.html
seachnasaigh ( ) posted Sat, 30 July 2011 at 8:38 AM
Attached Link: large enviro, Lothlorien terrain (no wallset), Poser render test
*(Ima70)*> Quote - Nobody mentioned RDNA Terradome and its addons > > > >
  Laurie did, in the first response to the opening post. 😕
Poser render test of the large (third size) enviro terrain, without the walls as I don't have the pano images made yet.  Notice the moist dirt streambanks, the terra rosa footpaths, and a few areas with exposed rock outcroppings.  This is easily changed by drawing red/green/blue onto a black canvas.  Poser then reads off the RGB components and assigns different textures and displacements to each color of the map.  The idea is that you can make footpaths or roads which fit your placement of trees and cottages.  You could also make red correspond to patches of garden, for example.
Lothlorien Poser test
This is the RGB map used:
RGB discriminator
I still need to make some low-poly filler trees which use mesh leaves rather than transmapped squares for the leaves, in order to populate the forest.  Using that method of modeling will allow Poser to render in IDL with the least RAM burden.
LaurieA ( ) posted Sat, 30 July 2011 at 8:42 AM
Very cool :)
Ometeotl ( ) posted Tue, 04 October 2011 at 9:20 AM
I like your "world in a tank" more and more, Seachnasaigh
seachnasaigh ( ) posted Tue, 04 October 2011 at 10:15 AM · edited Tue, 04 October 2011 at 10:24 AM
Thank you, Ometeotl and Laurie.  ^^  With the P9/PP2012 release out of the way, now I can get back to work.  In P4-P7, transmapped foliage for trees was the best solution.  Since P8 introducing IDL, such a myriad of overlapping transparency polys are a bad drag on rendering.  So, I've been concentrating on making trees with mesh leaves;  these render much faster.  Here is a test of a couple of low poly "filler" trees:
Lothlorien with low poly filler trees
I still need to import the terrain nether regions into Vue and render panoramas for the backdrop walls, and I'll make some equirectangular sky renders for the skydome.  (Glaseye made the sky in this test render).  And I want a low poly bush/hedge model, and maybe another low poly tree or two, for populating the enviro.
Other terrains will follow - an Australian outback, using the RGB discriminator to add roads for those Mad Max scenes.
     The medium and small enviros will allow denser foliage to be used, for less powerful computers.  I want everybody to able to play with this if they wish.
lmckenzie ( ) posted Wed, 05 October 2011 at 11:00 AM
"Also one can buy lots of great outdoor HDRIs if one doesn't have vue..."
sIBL is a great plugin to automate using HDRIs for various applications including C4D, Max and Maya. There's no version for Vue or Poser (though perhape someone might create them), but you can download some great free HDRIs from their archives. Highly recommended :-)
http://www.hdrlabs.com/sibl/archive.html
MistyLaraCarrara ( ) posted Wed, 05 October 2011 at 12:49 PM
poser dynamic hair makes kewl looking grass.
i can't find it right now, but i had a scene with the big horn grazing on a grassland.
seachnasaigh ( ) posted Wed, 05 October 2011 at 3:51 PM
Quote - i had a scene with the big horn grazing on a grassland.
  Moo, y'all.
    Oh, I forgot to post the pixie dust material.  Here 'tis.
pixie dust mat settings
Customized P9 splash screen:
P9 splash screen
LaurieA ( ) posted Wed, 05 October 2011 at 6:11 PM
seachnasaigh, that is so cool. Thanks :). I don't have Poser 9 yet, but from what I see, it can be used in Poser 8 as well.
seachnasaigh ( ) posted Wed, 05 October 2011 at 7:41 PM
Thank you, Laurie. :)   That material should work in P5 and newer.
MistyLaraCarrara ( ) posted Thu, 06 October 2011 at 9:01 AM
😄  found an old screen shot for the grass
seachnasaigh ( ) posted Thu, 06 October 2011 at 1:17 PM
Hmmm, Misty, I can see using that dynamic hair grass in the foreground of a big scene, while filling in all the background with the "cheaper" displacement grass.
Oh, an update:   after some experimentation, I've found these changes beneficial to the pixie dust:
pixie dust - version 2
