Mon, Jan 6, 10:09 PM CST
Subject: Help with VSS Shader System (Poser 6)
Acadia ( ) posted Mon, 11 July 2011 at 4:15 PM · edited Sun, 05 January 2025 at 4:08 AM
I'm behind the times and have just gotten back into Poser after nearly a 3 year hiatus.
I'm trying the VSS Shader and I'm suck.  I'm using Poser 6.
I went to http://sites.google.com/site/poserbagginsbill/vsshomepage  and downloaded the following:
VSS PR3 Control Prop
VSS Discussion
VSS Free Preview Release
I installed according to directions into my main Poser 6 runtime.  My VSS script is located in the following path:
C:Program FilesCurious LabsPoser 6RuntimePythonvss
I put the script into my main buttons for easy access.
I'm following the instructions at this link:  http://believable3d.com/resources/vss_for_dummies.php
Essentially what I've done is after loading my figure and applying a texture, I went to the Props folder and loaded "VSS_PR3_AO" to the scene.  I got a newer version of Poser error.  I loaded the prop anyway.
What I did next was click on the vssMainButtons.py which gave me 3 additional options after "2 hacks":   Synchronize, Render, Designer.
As per the instructions I clicked "SYnchronize".  This is the error I get:
------- VSS -------
Traceback (most recent call last):
  File "", line 2, in ?
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvssui.py", line 167, in call
    self.functionsi-1
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvssui.py", line 247, in userSynchronizeScene
    synchronizeScene()
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvss.py", line 893, in synchronizeScene
    Synchronize(figure)
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvss.py", line 866, in Synchronize
    source, smats = findVssSourceFor(target)
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvss.py", line 834, in findVssSourceFor
    things = scene.Figures() + [a for a in scene.Actors() if isOrdinaryProp(a)]
  File "C:Program FilesCurious LabsPoser 6RuntimePythonvssvss.py", line 887, in isOrdinaryProp
    return True
NameError: global name 'True' is not defined
Acadia ( ) posted Mon, 11 July 2011 at 4:51 PM · edited Mon, 11 July 2011 at 4:57 PM
I'm currently reading the VSS thread. Many, many, many more pages to go!  lol
I forgot to add that I'm using:
Poser 6 with all SR releases
A PC
V4
Windows XP Home
bagginsbill ( ) posted Mon, 11 July 2011 at 5:24 PM
Poser 6 uses an old Python where the word "True" is not defined.
In vss.py, insert the following lines right at the top and try again:
True=1
False = 0
Acadia ( ) posted Mon, 11 July 2011 at 5:32 PM
Thanks so much! I'll give that a try.
I do have PoserPro2010, but haven't installed it yet.  I'm kind of intimidated by it because I finally got the hang of creating lights in Poser 6 and from what I understand it's completely different in PoserPro.
Acadia ( ) posted Mon, 11 July 2011 at 5:36 PM
It worked! Thank you so much! hugs  I've been itching to try this out.
I'll post my results in the VSS thread to keep things together :)
