Poser can export the contents of a scene to a folder. This python script will copy the pz3 file, .obj models, and all textures, bump maps, and transparency maps!
Poser 7 - On the Scripts menu, select Utility, Collect Scene Inventory.
Poser 6 - On the Windows menu, click Python Scripts.
Click the Utility Funcs button.
Click the Collect Scene Inventory button.
Select Copy all to Folder.
Make sure you copy to an empty folder – you will have lots of files! Now use the files in this folder to import into Vue.
LVS - Where Learning is Fun!
A follow up to the post below. The vendor suggested I import the Poser 7 prop as an .obj file rather than a .pz3 as I had been doing. I did that and the problem may be gone ( I can't be sure until I see it textured), but I can't get Vue 8 to recognize any of the textures.
The names of the textures are showing up in the imported materials list, but they are all just a plain gray flat texture. and when i go into the advanced material editor and click on mapped picture in Color and Alpha it says "none."
Vue saw the textures when I imported as a .pz3. All the textures are in the same file as the .ojb file.
What am I doing wrong?
